Since an oil cooler installed, I've noticed my oil temperature stays at the lower end during city driving, usually around 76 ~ 80°C, where the turbo was mostly not engaged. Trying to raise the temperature I made a sliding window trying to restrict the airflow through the cooler. However it only resulted in a 3 ~ 4°C increase even after a few short sprints. I was hoping to hit 85~90°C after the cooler is blocked.
I'm curious what's your oil temperature with an oil cooler installed under the similar driving condition?
Also, In the winter conditions, would you be concerned such a low oil temperature might cause increased engine wear?
My setup: oil cooler with a blocking window, bonnet hood vents blocked, aluminum cooling under cover unblocked
Outdoor temperature: 18~25°C
Speed: mostly under 70 kph and 3000 RPM
