It was driving me crazy, trying to find the socket, and like you I was only able to find the Aliexpress chinesium parts. I also found that TE makes a 40 pin that seems compatiable but the male pins indeed only come as smt. I think stratified is using those aliexpress parts as basis for their flexfuel kit.All testing I’ve done is based on the GR Yaris Gen1, though I have some information that these CAN IDs also seem to work on the Gen2. I have no idea about the GR Corolla, but I suspect most of them should work. Your part numbers are correct.
As for the mating connector for the CAN Gateway, I tried buying a Gateway module from a hybrid Yaris in order to salvage the male connector. The connector is an SMT type with very thin tabs, which would be a nightmare to solder, and I don’t think it would last. But then I found an AliExpress listing for something that looks like it should work. I ordered two, but they still haven’t arrived, so I can’t confirm if they fit:
34 Pin Auto Instrument panel host connector DCM module ECU wire harness plug 90980-12E32 90980-12E35 6098-8852 6098-8854 - AliExpress 13
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
I've only listened to CAN messages, not sent any, so I'm not sure how the Gateway would handle that.It was driving me crazy, trying to find the socket, and like you I was only able to find the Aliexpress chinesium parts. I also found that TE makes a 40 pin that seems compatiable but the male pins indeed only come as smt. I think stratified is using those aliexpress parts as basis for their flexfuel kit.
Where do you find documentation like this?Thanks, man! I'll add them to the list and tidy up my naming.
No, I believe it's the real-time fuel supply for the engine in ml. It could potentially be used for momentary or average fuel consumption on your dash.
According to diagram, H62 is connected to the Bus Buffer ECU (Bus 7). I'm not entirely sure what that meansbut I am definitely seeing signals from various buses, not certain if it's from all of them.
It would be great if you could share those reversed signals with the communitybesides that i set up my AIM profile, i reversed engineered myself most of the values the ecu outputs. so all of the temp stuff, so have the oil temp. oil pressure, i also verified the brake pressure by logging via techstream to verify my units. so my values are tested on a grc. so not sure if they will match a GRY.
Yes, it's possible but for that you have to intercept CAN frames going to the instrument panel.Bit of a different topic, but hoping someone could shed a little light on whether this is feasible.
Is there any way to make changes on the CAN BUS so that the hazard lights stop flashing when the ABS kicks in? I believe this is called ESS and I want to disable it.
From what I see, they interface with the instrument cluster, not the gateway.God another product that has the 34 pin socket that interfaces with the network gateway… I swear that has to be a part produced by some company… drives me crazy I can’t find who makes the stupid thing…
