GR Yaris LW light weight lithium battery and charging options
Unplugging the electrical plug on top of the negative battery terminal clamp would likely do it. That appears to be the battery management system sensor for current flow, it would likely put the charging system into a default failure mode with an increased voltage output.
Yes, you are probably correct.
Its still a regular type of alternator with a Voltage Regulator so charge rate would be around 13.8 to 14.4 volts.
With the Motec, charge rate sits at 14.2 to 14.3 volts, its very consistent.
The smart system uses Duty Cycle to basically switch the alternator on and off very quickly to control voltage output.
