Brake Master Cylinder Pressure
OBD2 Mode and PID: 221004
Long name: Brake Master Cylinder Pressure
Short name: BrakePr
Minimum value: 0
Maximum value: 100
Scale factor: x1
Unit type: bar
Equation: ((A*0.9807)-10)
OBD header: 7B0
There are examples in this thread that give brake percentage, but they didn't work for me. They read byte B, which in my case is empty. According to Techstream, byte A is brake pressure. I think the scaling is close, but I'll recheck it at some point.
Ambient Temperature
OBD2 Mode and PID: 221141
Long name: Ambient Temperature
Short name: AmbTemp
Minimum value: -40
Maximum value: 100
Scale factor: x1
Unit type: °C
Equation: (A/2)-40
OBD header: 7C0
Intake Air Temperature @ Manifold
OBD2 Mode and PID: 0177
Long name: Intake Air Temperature Manifold
Short name: IAT_Manf
Minimum value: -40
Maximum value: 100
Scale factor: x1
Unit type: °C
Equation: C-40
OBD header: 7DF
It's quite interesting to combine all three intake and ambient air temperature. Gives quite a good picture of what's going on.
For reference, Torque Pro's standard "CACT" shows the temperature after the intercooler, while "Intake Air Temperature" - the MAF temperature.
You can see how the MAF temperature shoots up when the airbox flap opens, as well as the heat soak at the end of a ride when going slow or idling. Would be interesting to see similar log from the track.
If anybody has additional parameters they'd like to read, let me know. I might be able to find their PIDs.
