Hi everyone,
I wanted to share an issue that several owners in Spain have noticed with the GR Yaris GR2. Under certain conditions, the turbo seems to get restricted and won’t go over 0.8–0.9 bar for a few seconds or even a couple of minutes.
The strange thing is:
  • No error messages appear.
  • Nothing is stored in the ECU.
  • The car “fixes itself” after a short while and boost returns to normal.
How to reproduce it:
  • With high outside temperatures and the car already hot after some spirited driving.
  • You stop for a few minutes (for example to refuel, 5–10 minutes).
  • When you start again, everything looks fine, but under hard acceleration the turbo doesn’t boost past 0.9 bar in any gear.
After some seconds or a minute or two, everything goes back to normal.
Has this happened to anyone else? Could you try it and see if you can replicate it on your GR2?
Later I will open a specific thread.
You know what I thought: if you drive for a long time (even going normally), and you stop for 2 minutes, when you return you just turn on the ignition leaving the car off... you will notice that the temp is close to 100 sometimes more (I even saw 110 once).... because the sensor is output and reads higher temps when off... as soon as you start the car, the temp returns to normal 90-92, could it be that at that moment it reads that it is hot and takes a minute to check that everything is ok before giving power?
Interesting. Would it help to shield affected sensors to prevent the heatsoak? Or is that already a factor the RnD engineers kept in mind and added an offset?
Please explain to me so if it happens to me I already know... I use the translator and sometimes it's not clear... basically if the car is at the correct temperature (90-96 degrees) I stop, turn it off and start again after 5 minutes, the car even if it is at the optimal temperature, from when I start it in the first minute it doesn't go above 1 bar?
Correct, that’s exactly what happens: when you restart the car while it’s hot, for a few seconds or even minutes the turbo doesn’t go beyond 0.9 bar, just like when starting it cold.
I haven't tried it when the car is cold 😥… I don't want to… but until when does the message to avoid hard acceleration come on?! I'm happy so if I leave it with someone they can't be too much of an idiot…
What sensors do you use?
I wouldn’t think of pushing the car when it’s cold either, I was just mentioning it for comparison. Apparently, when you restart it hot, it behaves the same way as when it’s cold, but in this case no warning message shows up on the dashboard.
After digging through the service manual, I think putting these two together explains the situation:
Technical question: Can't the entire MK1 exhaust be fitted to the MK2? Or are there parts that work? For example, a downpipe?
It’s all different. Cat, GPF, Backbox. The diameter of the pipe is bigger and joins are in different locations and the tips are spaced out 2cm wider so you would have to use the old bumper if you managed to step down.
Anyone know the part numbers on the two rear plastic covers on the rovanpera/ogier cars?
£57.45 each here + shipping + duty + VAT
Bolts and clips are £1 each
679usd including shipping and tax 🥵
