- Thread starter
- #101
Is the GR Yaris ECU finally cracked?
Ok. MPS says 350/360 is no Problem. The Spring Problem is in the boost level with 380 + HP...DTUK works very well on a stock car and certain mods.
When you‘re in the 350/360hp range, you‘ll need to upgrade valve springs to be safe…
Can you clarify the spec of the car for the black dyno sheet, I'm not sure what it was as the difference with the others wasn't that big...DTUK works very well on a stock car and certain mods.
Black was completely stock.Can you clarify the spec of the car for the black dyno sheet, I'm not sure what it was as the difference with the others wasn't that big...
So the black one was stock hardware.Black was completely stock.
Increase over stock was around 50Nm and 20HP.
Yeah.I think I was thrown off track by your comments in the vid before you got the results, speaking of 25-30hp difference with just the exhaust, so I was looking for a larger delta somewhere. So that was perhaps a bit optimistic, and its more around the 20hp mark for turbo back straight exhaust only? With a tune the difference will only become bigger obviously.
