GR Yaris Twitching
grydoc
Dedicated member
I’ve had the car 6 weeks and done 600 miles (Circuit Pack, no mods). Grip and traction is superb but I’ve noticed one little quirk and I’m wondering if it’s normal. When accelerating round a roundabout from standstill there’s a little twitch from the steering every time I let the clutch back in after a gear change. I’ve tried to work out what’s going on and am wondering if it’s a little lift off oversteer when I push the clutch in which is reversed when the drive re-engages? It’s not too unpleasant, adds to the lively feel, but it’s not pleasant either if that makes sense.
Anyone else noticed this?
Any thoughts ? Geometry? Normal for 4WD performance car?
It sounds like torque-steer - lots of power and an LSD. I drive around in Sport Track Sport mode, just because most drive is split to the rear and it lessens the need to fight the wheel.
I think this is normal, torque steer as Araf said. I never drive in normal mode but I remember the steering wheel is a bit more lively under acceleration, not surprising really. If I haven’t driven my Clio for a while I really notice the torque steer when pushing on, and that doesn’t have any torque!
As others have said torque steer. Happens in any powerful car.
Try sport mode as it puts 70% of the power to the rear wheels. Should help a little bit.
I've just amended my post. I think it's 'Track' (twist to the left) with rear bias and 'Sport' is 50/50
Must be LSD-related, as I've not experienced this in my convenience pack car.
I’m not sure it is the LSDs, or at least it doesn’t need to be that, as the DC2 Integra had one and exhibited almost no torque steer. Although that really did have no torque, around half that of the GRY anyway.
It took me a while to realise that the electronic driver aids interfere a lot during hard cornering under power, even in the dry. It does this horrible thing of interrupting the torque mid-corner. Put in it expert mode and this disappears.
Thanks for all the replies.
Yes, lane assist definitely off. I’ll experiment with Sport mode, usually drive in Track. It could be torque steer but not sure as I don’t really notice it in other situations.
doesnt sound like torque steer to me - especially if it is just when the clutch comes out. Torque steer would happen at any time when you get on the gas.
you sure its not to do with the hand movement back onto the steering wheel as you move off the gar stick? A little inadvertent tug, so to speak!
I cant say i have noticed what you describe
Does it only do it going round a roundabout or whenever accelerating in low gears?
If it's just on a roundabout it could be tramlining in the ruts that hgv's create when turning on a tight lock, otherwise it's possibly torque steer as already suggested.
Could be the answer, they were all between 3 and 4 psi overinflated. Not driven it yet since dropping them.
That could be it. Most of us were treated to 38-40 psi all round by our dealerships. It has noticeably less bite and overall grip with that much pressure. The ride suffered too but don’t remember it creating a twitching of the wheel.
How aggressive is the acceleration and the clutch release? I assume your not flat shifting or using a trailing throttle?
Are you catching the rpm as it falls? Do you have iMT on?
Car is noticeably feeling better with proper tyre pressure, much more settled.
On further analysis I think the twitching is actually just me not being smooth enough in releasing the clutch after an up shift when accelerating round a corner. Thanks all for your suggestion.
