Thank you.I think you need to press the middle button on the right steering wheel control.
I don't think PPF need to disconnect the battery...Would they have needed to disconnect the battery at all, to dismantle anything? Not sure if that resets the counter.
I wondered if maybe they removed the light clusters or something to get behind them, but even then yeah I agree it would be a be much.I don't think PPF need to disconnect the battery...
Reset mine every time I fill up (unless on a road trip).I haven't reset mine since I bought the car new!
I push the trip reset button when I fill up.Reset mine every time I fill up (unless on a road trip).
I am equally sad as I record my usage in 'fuelio' app on my phone . . . .I push the trip reset button when I fill up.
Sad to say I then record the mileage and the litres added in a spreadsheet to calculate the mpg.
I could be wrong but I thought the interior light goes off after a certain time if you leave a door open, so there wouldn't be much of a drain from doing that.They told me the battery ran flat because they had to keep the doors open during installation. Is that true?
but as you said disconnecting the battery doesn't reset the counters.
That'll be the puddle lights then.They told me the battery ran flat because they had to keep the doors open during installation. Is that true?
I'd be concerned about that, they may have knackered your battery.They told me the battery ran flat because they had to keep the doors open during installation. Is that true?
