GR Yaris Power consumption air conditioning
Heliomalt
Devoted member
Helvetia
Does anyone know how high the power consumption of the air conditioning system is? I haven't found anything on the net. How does this affect the performance of the car? PS and torque?
Did you measure it or did you get it from technical documents?
I think on most modern cars A/C is disabled at full throttle and probably other times too, so it shouldn't really sap power when you need it. Shouldn't.
I'm not worried about the car's performance, and it's not like it's noticeable. It's purely a technical concern, not internet voodoo, not an oil conspiracy, or a matter of faith.
Errrm, okay. Then I'll pluck a number out of the air and say 1% losses which would be precisely 2.57bhp on a standard UK mk1.
But it all depends on RPM and a million other variables. Would anyone else like to volunteer a different meaningless number?
Ate a clown for breakfast?
Sorry for you, this isn't about questions like which exhaust and intake are the best and sound the best. Sometimes you just have a technical interest in something, nothing more and nothing less.
Unless you can get the datasheet for the AC compressor (probably going to be made by Denso), you won't know the true figure but it will be around 3kW.
The alternator will draw upto 2kW. So total load on the engine will be around 5kW or 6.7BHP.
Second that.
Because in most modern cars they can switch it on or off as they wish, after a certain throttle %, it‘s just off.
We tried it once to measure the difference on a dyno, just for fun, but it wasn‘t possible.
Ate a moron for breakfast? Sorry for you trying to find technical info that is unavailable and irrelevant but good luck to you sir. Maybe you could discuss the finer points of dyno losses next. I'll go with 22.34% at 6345rpm on Wednesdays
I don't think that is necessary and not how we do things here at the Zoo.
There is nothing wrong with being inquisitive and having an open friendly discussion.
Understood and my apologies. I offered a friendly reply to a question about A/C performance losses saying that it didn't really matter as there's effectively none, but that was somehow deemed as voodoo/conspiracy/faith due to my lack of technical knowledge as I only care about intake and exhaust noises 🤷‍♂️
You gave the best answer with 3KW. But I doubt that's constant draw even with A/C enabled. It just doesn't matter with it being condition-based and cut with throttle usage - there's no single answer to the question. But aaaaanyway, I'll butt-out now.
another interesting aspect of this discussion...
>>the AC-on seems to keep the radiator fan running all the time, which I feel that may "stabilize" the coolant and engine compartment temps, positive in my book.
Isn’t that quite normal? My wife’s 14 year old C1 does that.
-Apologies for such triviality! but I'm just trying to add something constructive/useful to this thread.
Anyways, my point is that AC-on may help with common GRY concerns: intake/IC heat-soaking and engine compartment temps maybe people wouldn't have to replace those coil-packs so often after all.
Only when stationary.
When the car is moving with more than , let’s say, 80km/h and more, there‘s so much air flowing through your front grill, that the fan is basically just in the way and it would be better without it.
But while stationary it‘s absolutely necessary.
Thank you for the numerous answers. Interesting, especially when I think of our small car (Aygo 72PS), where you can clearly tell whether the air conditioning is on or off. That was actually what prompted me to ask this question, as I said, pure curiosity and technical interest.
@Heliomalt I'd like offer my apologies for yesterday. I still don't know what sort of answer you were expecting, but I took your comments as a dig and my response was out of order. I won't make lame excuses like getting out of bed on the wrong side.
I did consider deleting or editing but it's out there now and I think the internet in general could do with a little more humility. So I'm sorry. And you don't have to accept or say it's okay as it wasn't.
