GR Yaris Check Engine Light (CEL)
l0uski
Hi guys,
First time posting here.
I'm having an issue with my Yaris with regards to the check engine light being on constantly.
A bit of a back story with my car and its current modifications: It has an Eventuri intake, Armytrix catted downpipe (200 CEL) and catback exhaust.
Prior to having the downpipe fitted, car never threw a CEL but immediately did after installing the downpipe. I didn't worry too much about this as I had planned to get the car tuned via Ecutek. Long story short, my tuner has tried multiple times now to remove the CEL, but after 30 mins to 1 hour of driving it flicks on again. He has even switched off the 2nd O2 sensor reading, but still hasn't helped.
I'm at wits end now as to what is causing it.
Any help or insights would be greatly appreciated.
Cheers,
Alan.
Hi guys,
Cheers,
Alan.
If I was you I would put the original downpipe in and see if it still throws codes. If not then you have isolated the issue.
I'm thinking of doing that even though I don't really want to, but I would prefer to see if anyone has encountered this and been able to address it with the aftermarket downpipe/cat installed.
So what code are you getting, P0420?.
If your still getting the above code then your tuner has not successfully disabled it (the second O2 sensor).
You could try a 02 Sensor extension, it may work.
Yes it's a P0420 code I believe.
Just to add, tuner already fitted a mini o2 cat spacer which looks something like this. Would this be much different to those o2 spacers?
That looks like it should do the same thing.
Toyota catalyst test is an O2 storage capacity test. It changes the mixture and looks for response time from the downstream sensor. An aftermarket cat isn't nearly as efficient as the factory one. It has fewer cells, so less surface area, so less O2 storage capacity. Even stock replacements that aren't OE will usually set a P0420, so I can't imagine a race one won't.
Adding those extensions that dampen switching from the downstream cat don't work because most modern systems use AF sensors and don't switch.
Agree. A 200 Cell will certainly throw a CEL even with a extension. It use to happen on my Fiesta ST ( till it was disabled by flashing the ECU) and it also happened on my GR when I changed the downpipe.
I think it only takes around a 3% drop in CAT efficiency to trigger a CEL on current vehicles needing to meet the latest emission standards.
Yeah that seems to be the case with my car and it's a bit strange that it wasn't successfully disabled as Ecutek specifically sent my tuner an updated file to allow disabling, however it hasn't solved the issue.
I think its also a case-by-case situation as I've been doing some searching on this forum and GRYarisUK and some people have installed aftermarket downpipes/cats with no issues.
It can be fickle. I fitted a sports cat and cat back on my M2 with no issues, others fitted the same cat but different exhaust and had cel.
Hi Alan, did you resolve this? Mine is also playing up.
Do you have an aftermarket downpipe/cat? They will always throw a CEL unless accounted for in an ECU tune.
I recently got an ECUTEK tune and told the tuner that I would be installing an aftermarket downpipe in future. The tuner changed the ECU settings so it won't throw a CEL when I get around to fitting it.
I too am having a CEL after replacing downpipe and front pipe (and removing cat). Its error code P2271 which the interwebs says "Bank 1 Sensor 2 oxygen sensor is reporting a "stuck rich" signal, meaning the engine control module (ECM) detects a signal that the fuel mixture is consistently richer than expected". My interpretation of this is that as I have removed the cat the 2nd 02 sensor is reading richer than it should. I have added a 90 degree sensor spacer thing - however there is flexibility in terms of how much "flow" you allow the downstream sensor to see, depending on how much insertion into the exhaust flow you select. I have yet to try adjusting this, but was wanting to know if I need more or less insertion into the exhaust flow? I presume less but would love to hear back from someone with experience in this area. Many thanks!
Can't help on O2 sensor length, but removing the cat will throw a CEL. You can change a setting within ecutek to account for this, not sure what others would do with the stock ECU. I would contact a tuner familiar with the GRY.
