GR Yaris Turbo inlet dust
MarkoS
Took off Eventuri after some 10kkm and there was a visible thin layer of dust in the turbo inlet pipe. Same mechanic put it in the car, hadn't noticed anything worrying then. Should I be concerned by this?
Air filters cannot filter everything, which is why oil changes are so important (among other things).
I would be really concerned about it to be honest... so either there's an uncoupled /lose clamp junction or the filter element is subpar/junk (compared to oem).
After all: an air filter main purpose is to filter.
And make no mistake, those thin particles act as sand-paper inside the engine.
It’s well known that the only thing that offers decent filtration is the stock panel filter.
and that really annoys me, since they claim "top-notch" filtration in their homepage...
Eventuri say clean the filter every 5,000km’s this is double but in my head that should just be a performance impact from a clogged filter rather than a dirty filter letting more particles through?
Have you sent the findings to eventuri? See what they say... Although I expect they will say clean at 5k miles or whatever is specified.
I would be seriously concerned.
The problem is not just premature piston, piston ring and bore wear but damage to the turbo compressor wheel.
It probably rotates up to 150,000 rpm and when the dust hits it rotating at that speed the edges wear on the wheel (fast).
There is a test standard for air filter filtration but not many manufactures bother with using this testing standard because their filters preform very poorly.
Want to know how well your aftermarket air filter is performing?. Remove the MAF sensor and using a non residue electronic cleaner, spray the sensor over some white paper towel and look what runs of it. It should be basically clean.
Most aftermarket air filters are very poor at filtering fine to very fine particles. Marketing sells aftermarket air filters not performance.
The only filters I have seen that out performs OEM is Nanofiber.
Just another thought on this as other owners haven’t mentioned any issues and they are used across multiple makes of cars with no reported issues. And indeed at 5000km you hadn’t spotted anything so did you possibly not refit it correctly when changing the filter.
