GR Yaris whiteline lower torque arm bush kit
foxspeed
sat behind a laptop moderating
managed to fit the whiteline bush kit to mine today took advantage of time off work and a "window" of opportunity!
fairly easy to fit just wish toyota made the under tray with less fixings :rolleyes:
bit more vibration on tickover but once on the move nothing to worry about takes quite a bit of slack/shunt out of the driveline when changing gear
Nice. Will fit mine sometime in January, will probably open it up a tiny bit to reduce stone cold winter vibrations a bit...
I have a white line bush kit waiting to fit but im not sure on the torque settings.. gr forum says large bolt 190Nm and four gearbox bolts 44Nm .. fensport state large bolt 110Nm and four gearbox bolts 60Nm .. out of interest what torque settings did you set too
22mm bolt = 120nm (with a little bit of an extra turn)
13mm bolts = 60nm
What condition was you mount in ? mine wasn't happy :oops:
Waiting on a replacment
Great pic, from the very straight line visible on the bottom part of the gap that looks very much like a mould outline, and from the size of that gap, I now doubt that it actually is defective at all. Just a bit messy overflow in the mould (as is very apparent to the sides) that gives the impression of a joined part, where it isn't supposed to be joined at all?
Anyone else see what I see, preferably from a in_your_hands part?
Possibly but it certainly looks like the rubber pulled away from the alloy surround
I guess I will find out when the replacement finally shows up
Well talk about a coincidence, I popped into the dealership today on an unrelated mater (building reception counters) & my gearbox mount had turned up
It is also "broken" at the front like my one...there is a surprising amount of movement in it......
Will pull my one out tomorrow & compare them :)
Already looks broken....
The more I think of it, the less it makes sense it is supposed to be attached there. When in tension there, it is in the main function/movement of the bushing (engines rocks back on power, pulling the arm) and on the other side there is a gap AND a bumper there, allowing quite some movement. And by rule of rubber bush design, rubber prefers compression much more then tension under load, as can also be seen of the wedged shapes to the sides which allow much movement and activation of a lot of rubber under compression+shear which gives hysteresis/damping. Lastly, bushings of similar design on other cars are indeed open on both sides.
So if I was very sceptical this 'tear' was an issue in the Safari place, now I'm very sceptical it was ever supposed to be attached as by above reasoning movement allowed by remaining design would soon overwhelm it.
And for similar reasons, pretty sure if for mysterious reasons it is attached, it was not never going to last.
However with an insert, there will be less movement and any attachment is more likely to remain....
Yea that was obvious from looking at it. It's not part of the outer mould. It's designed to move forward slightly and hit that bump stop
Glad we got it cleared up. Thanks @Kiwi Greg and hope your dealer i open to returns of 'broken' parts lol
It does look a bit odd in the design, near enough like it is supposed to be attached. Oh well, one worry less for a lot of us!
It is under warranty, it does look like it should be attached
the same as this.... dont think its to worry about it seems to be designed like that
Yes that's how it appears, certainly looks "broken" when you look at it
I have mine out of the car & just going into the dealership, its amazing how much they move, completely understand why the Whiteline sandwich is a good idea
Will most likely keep my original one, we will see :)
Installed mine a few days ago.
I chose the whiteline because it keeps the orignal vulcanised mount, and because it fills the holes fully so reducing risk for undue rubbing and wear.
However, the big lobes that are not loaded under power (as the core is pushed the other way) were a bit too hard for my taste. They are just there to reduce the rocking of the engine but being so hard would in my mind transfer unnecessary amounts of NVH. So drilled some holes in them so they flex a bit when squeezing them hard with my fingers, making such holes in the mould are a bit of a hassle I suppose...
For me, I notice a bit sharper response on initial throttle, and indeed slightly more positve shift. Both appreciated when on it. I also notice more vibrations on start-up, and a bit harsher running of the engine up to 3k rpm ish, with some more pronounced vibrations through the shell. Mostly noticeable when engine is cold (its freezing here) and it almost completely disappeard with heat in the engine and I suppose mount also.
Also, once before I did manage the car to wheel-hop, I suppose this will be less pronounced with the insert.
None of these changes are night and day, but rather subtle. I know this is how I perceive it, because I can be quite forgetfull and yesterday I already forgot I did this, yet noticed the cold engine sounded bit different/harsher lol.
So all in all a little shift in compromise, from comfort towards sportiness. Non-essential imho but I do like it. But I'm happy it didn't go further, that would throw out the existing balance of properties of the car.
