My transfer case had to be resealed at ~23.000km (~14.000 miles) as the factory sealing started to leak. This was covered by warranty.
Now, at 3 years and 68000km the transfer case is heavily leaking oil at the rear output shaft. Will know the details in a week or two when I get back the car, for now the main suspect is transfer case rear output bearing 36250-42030
No driveline vibrations/annoyances whatsoever (had the broken/lose transmission mount, but fixed a long time ago)
The car is fully stock, been only using stock size tires, around 2000 km driven on track, the rest as a daily...
Gearbox/diff/transfer case oils changed every 10.000km...
I did have 'awd overheat' messages on a very few occasions in the first year or two, there was an AWD software update that seems to have fixed that
@Diyman25 wrote a good post on transfer case/turbo location that probably explains why oil sealing fails prematurely
I've read about a few broken transfer case housings on tuned cars with 255-265 width tires, but not much stock car / oil leaking related
Anyone else had similar issues?
