GR Yaris The infotainment is angled the wrong way...or is it?
Gyp
I've seen mention in a couple of reviews that the infotainment screen is angled to favour LHD cars and when sat in the car that definitely feels like it's the case.
I looked at a standard current Yaris today and that was clearly straight across the car and wondered it that enclosure would fit the GRY...
But on looking at mine now I'm home, the one in the GRY looks to be straight across as well, not angled.
so is the infotainment angled to the left, or is it an optical illusion?
I tried to line up with my laser level without success, but using a straight edge it looks perpendicular to the body.
I think we only believe the angle's wrong because one road tested said it was and that false information stuck.
I wish it was angled towards the driver though.
I believe it's actually dead straight.
We've been used to so many cars having such controls angled towards the driver, that straight now feels wrong.
What does seem to change between LHD and RHD cars is the volume control. That's placed at the side of the driver, which I think is a nice touch. (y)
The infotainment on my other cars are dead straight, so it can't be that; it might be that the proximity to the driver makes it odd.
I hate having the volume on the right as every single car I've ever driver for the last 40 years has had the volume on the left and I don't find the volume buttons on the steering wheel very intuitive.
As they manage to put the pedals in the same order on every car, they should do the same with the buttons.
For various reasons we've ended up with 3 cars in the family (toyota, mazda and skoda), all of which behave differently - the radios all do the same but are different, buttons in different places, behaviour of the cruise, behaviour of the central locking (don't get me started on the impossible to find clitoris lock on the boot hatch), reversing sensors - or not, lights, heating.
I'm getting too old for this. I think I need an Escort with wind-up windows, an AM/LW radio and an out of date road map in the glovebox.
The infotainment is dead straight though.
Not just me then!
....(don't get me started on the impossible to find clitoris lock on the boot hatch)....
This is one i certainly have licked.......:giggle:
  • Haha
Reactions: Gyp
Having just looked at a couple of Toyota photos, the knob swap isn't across the range.
Is it just in the Yaris (inc current non-GR variants)?
seems in the right place in the GR Corolla....and the newer system
I wonder if it's higher res and could be retro-fitted.
Mind you, as a replacement infotainment head unit for my Skoda is over £3,500 plus fitting, I doubt it would be an option if Toyota parts are anywhere near VAG parts
First thing I noticed when I sat in the car was that the screen isn’t tilted toward the passenger (left hand seat) but in fact perfectly straight/perpendicular to the centre line of the car.
Actually it was the second thing, the first was that there was plenty of headroom.
The internet is mostly wrong.
I think it's a good thing that the volume control is on the right, which falls much easier to hand. I wish the indicators were on the right and not LHD spec, though it seems an odd quirk that for UK cars we have had the LHD setup for decades now. I really have no idea why that is.
It makes sense to have the controls in the the same relative position where possible as it means moving from one car to another easier, and manufacturers settling on an unofficial standard helps
  • wiper on the right stalk
  • indicator on the left stalk
  • accelerator on the right
  • clutch on the left
  • brake in the middle
  • H pattern gears start top left and finish bottom right
all work whether whether you drive the left or right hand drive version of the same car. Makes life easier.
  • radio volume on the left - oh, maybe not
  • radio tuning on the right -err, maybe not that either
Because it's not standard (and the steering wheel volume controls are different on all of our cars), turning the volume down to avoid distraction is in itself distracting.
Do the LHD Yaris have the volume on the left near the driver?
Is it a hardware or a software configuration i wonder?
... all work whether whether you drive the left or right hand drive version of the same car. Makes life easier.
I appreciate that consistency makes life easier.
Safety first, though, and in that spirit, having driven the same manual car in LHD & RHD formats, I found it safer to have indicators on the right-hand stalk in RHD cars. That setup allows you to operate the steering wheel and indicator with the same (right) hand, while changing gears with the left one.
What I found even more puzzling is how some cars (at least some older VW group ones, I believe) have the reverse as push-down, left and up. I found that, in RHD cars especially, it was too easy to aim for 1st gear and end up putting in reverse by mistake.
Surely - safety first and all that - you will be declaring your intentions with your indicators well in advance of the movement itself?
If you're indicating at the point you are steering, surely that's too late?
Or if you are indicating whilst not steering, but whilst also changing gear, then you don't have a hand on the steering wheel?
Having discovered that the LHD cars have all the knobs and buttons where I'd expect them to be, I wonder if it's possible to fit a LHD radio to a RHD car and still have working nav etc
Sometimes you just want to blip the indicators, or cancel them, or make a late decision on a busy area, etc. I'm now used to them on the left, but preferred them on the right, as with all the Japanese imports I've had.
Totally agree felt much more intuitive in my Classic Impreza.
I suspect with a lot of things, it's what you're used to.
And having run Citroen CXs and GSAs for a few years, no modern car has the controls in the right place :-)
