GR Yaris Enhance performance owners wanted.
Swede
Absorbed member
I am looking for owners of systems from Enhance Performance.
I am interested in one but i need to know about the sound from the different versions. Non res vs res, track friendly vs ultimate.
There is not much out there on the internet 😃
I’ve got the resonated ultimate system gpf back. Far louder than I’d anticipated, I was hoping for a note like my old fiesta st in sport mode but soon got used to it and like it. It’s a bit vibey and bassy but I think it suits the car.
I’ve since added a whifbitz opf delete pipe, slightly deeper on idle, louder on the gas.
Both cracking quality
I’ve got the track friendly, GPF back, resonated exhaust from Enhance. As Mark mentioned they really are excellent build quality. I think they market my setup as the quietest one they sell, it’s spot on for me. Has a lovely burble on tick over and possibly a very slight drone cruising at speed but that’s drowned out by the tyre noise! Just gives the car the lift in noise it needs.
I haven’t heard any other exhausts in person so hard to properly compare, but I’m well happy and wouldn’t consider changing it for anything else I’ve heard on the internet. I have a cold start vid somewhere, I’ll try to find it and post
Any fault lights/error codes with the GPF delete Mark? I could be tempted further down the line
No, nothing at all. I went for the whifbitz section as I’ve no interest in changing the cat etc and it was cheap on Black Friday. Cracking quality again , only downside, after fitting it I had too fit powerflex rear exhaust mounts as the enhance section was sometimes touching on left hand tight tyres. Fine now tho with those mounts
Seems to Rev far keener higher up than with the gpf
Good to know, thanks. Out of interest whereabouts on the car did the exhaust end up touching after fitting GPF delete? I assume you meant it was touching on left hand tight turns rather than anything to do with the tyres!
I’ve heard of some Milltek systems rubbing on the driveshaft, though not sure if that’s an installation problem rather than a manufacturing problem.
It was where the rearmost right rubber mount fits. It was allowing the exhaust , where the mount slips over, to touch the car body. Could notice it turning left out of my works car park , if you shook the exhaust left to right you could hear it then. Fitting those two uprated mounts limited the movement, no probs since
Thanks guys, i am considering a system with GPF delete with Sports cat and downpipe. Would that make the car even louder?
A track friendly but non resonated. Would that be louder then a resonated ultimate system you think?
Appreciate your time and thoughts.
I expect a downpipe, sports cat and GPF delete combo would make the car significantly louder! If it was me I would get the resonated track friendly exhaust as, for me anyway, it would be too loud to go non-res with the extra mods you have planned.
You’re probably aware of this anyway but the Enhance system is modular, so you can swap out the res/non res section. Although it would be pricey having to buy the two sections….
If you want to do track days they might advise you to go resonated to pass noise restrictions. They’re pretty prompt via email or just give them a call for some advice
Can’t seem to get my cold start video to upload either…apologies!
Me neither, the world doesn't revolve around social media.
You wouldn‘t belive the opportunitys i got and things i‘m able to do, thanks to my social media accounts…
But you‘re right in one point.
It has nothing to do with the real world.
Social Media is a complete different world from the one we‘re living in.
You can choose that it has no effect on you in not using it, but it can have a major impact in your life (good and/or bad) if you start using it.
Even warfare is done on social media nowadays, it IS a big part of the world today.
I think this is a pretty good option. It has its price but you can choose if you want it loud or not cause of valve control.
You can hear it here.
if you join the "Zeitenjagd 100-200 km/h" Grp on Facebook you will see a 400 hp Yaris with this exhaust installed aswell.
