GR86 Slambert Twin Hitch - Import from USA
AE86
Fascinated Member
Has anyone based in the UK imported a Slambert Twin Hitch from USA?
I’m tempted to get one but wondered if anyone had done so previously so I can work out import taxes and delivery costs.
Looking at their website they charge $80 for UK delivery, so $379 total. You will then have 20% VAT to pay on this plus import duty up to 2.5%.
Hello,
I’m currently getting drawings made up so I can get some bars made with a local machinist. This will just utilise the tow eyes with two long bars to enable a couple of Thule bike carriers to be attached. I will share the design once made for others to use.
See this link from a GT86 forum which gave me the rough design -
https://www.gt86ownersclub.co.uk/th...07037&nested_view=1&sortby=oldest#post-107037
Cheers
Sorry for the thread revival but did you get any further with your project?
Not a problem!
They are made but yet to fit the bike rack to the bars. I know they fit, but as others have pointed out on the GT86 forum the M10 fine thread itself is slightly loose fitting inside the towing eyes - I used an allthread instead of turning the threads on a lathe, so didn’t have the opportunity to make the thread diameter any larger… however, when the rack is mounted I expect it will be more rigid. Kids are getting back into their cycling again now, so will get them installed soon and report back.
I made mine from solid 30mm stainless bar at about 900mm long thinking I could get 2/3 bikes on. It may have been a little ambitious and lead to me reducing the length a little due to the weight.
Will send a further update in the next couple of weeks - and put the drawings up when I know it’s not a death trap!
Thanks
I love your honesty ha ha!
It would be fab to be able to get two bikes on the back as I’ve already got Thule bike racks which I use on my wife’s Q3, but she is whinging about me using her car at weekends!!!
Wonder if you could u bolt a bit of box section to 2 standard towing eyes and mount a hitch to the centre if we’re talking 10kg of bike as load 🤔
This may well be a better approach (as the Slambert hitch), but as I already had the roof rack type bike mounts I continued down that path using the Thule gear I already owned!!
Talking about bike mounts, I used M16 threaded rods, aluminium square tubes and a lot of 3D printed carbon-reinforced Nylon to make a bike mount for my car. There is some wobble due to the loose fitting M16 and the sheer length of them (500mm). I used PPA-CF printed sleeves to reinforce but still some wobble. Should be safe for use though still.
