GR Yaris HEL rear diff oil cooler kit feedback
DanGR
Hi guys,
I installed the HEL rear diff cooler with the electric pump and the thermostat.
I'm looking for feedbacks from those who installed it.
I'm wondering if the noise of the pump is normal or if there an issue (not enough oil maybe?):
Thank you in advance.
That does not sound normal to me. That noise would drive you around the twist. Sounds like the pump is cavitating (sucking air).
I assume thats where HEL recommend mounting the pump.
How much extra oil did you add to the system to compensate for the lines and the cooler?.
Yes that’s where the pump is to be installed. The instructions say to add 450 ml of oil, which I did. But it’s difficult to not lose a little bit of oil when trying to fill in the system (through the line going to the left side of the pump).
Thank you, I just needed confirmation this noise is not normal. Will see how I can add like 50 ml or a little more.
You could try priming the system. Grap some rag and with the pump running crack the pump outline till you get some oil flow. The oil should look clear. If its foaming and air rated the pump is cavitating.
Generally with a hydraulic system the inlet to the pump should always be below the oil level of the reserve, the reserve in this case is the differential housing that's why I asked about the mounting position. Good luck.
I assume the cooler is after the pump outlet (return side).
Thank you @Sekred I will try that.
For now, I got this answer from HEL when I show them the video and asked how to fill in the system in the easiest way:
I can hear the pump in your video but its hard to get an idea of how loud it is when activated. Has it got louder over time? Are you able to remove the end fittings from the pump and inspect the gears of the pump?
Ofcourse there will be a noise but during testing I didn’t notice it to be too loud on our car.
I don’t think that it would be caused by a lack of oil unless it was substantially low, but unfortunately the best way to fill is through the hose as described in the instructions. To drain the whole system for an oil service, disconnect the hose ends at the lowest points of the differential and oil cooler and drain from there.
Here are some pics of my installation:
And you can see the instruction manual here: https://auto.helperformance.com/umproductattachments/productattachment/link/id/15/
Hi guys,
I‘d say it sounds about the same as mine.
Maybe a bit louder.
They have very exact instructions on how to fill the pump through the pipe.
It‘s not very fast and you need an extra pair of hands, but it‘s quite simple to do it.
Thanks for sharing your experience with this pump @Phil1291
Yes I followed the instruction to fill it the first time, when the circuit was not primed yet. I was wondering if it's the same procedure when circuit is already primed. I guess a lot of oil will go out if I disconnect the 90° hose.
This is probably a dumb suggestion, but, maybe check how tight the mounting bolts are torque'd (pump and mounting plate)? The preload on the mounting bushing will largely change the vibration frequency that generates the noise.
But also - these mechanical gear pumps do run a bit loud
Hello everyone, some follow up:
I did what you suggested and there was no foam and oil was perfectly clear.
Anyway I decided to add another 50ml of oil through the recommended line.
I did 2 track days since, all seems to work well and the noise is a bit lower than before.
Yes they are. I think that's the normal noise of the pump.
