GR Yaris Review Ulter OPF/GPF back exhaust ECE – nice sound and great price
jep considering ulter is cheap its actually a bargain when it comes to sound, performance and weight.
I was considering TI exhaust but hard to argument spending 1.5k€ more to get rid of 4kg.
sun was shining today a bit, temperature above zero. washed the car and then in the afternoon got the idea to try to add the additional brace for ulter back box.
lifted the rear up and started fitting the extra chassis support for the exhaust.
I'm my logic the brace does not fit there unless chassis is cut so decided not to use the extra support. Another idea could have been to bent the 90 degree support brace to 45 degree but it would been bit weird install in the end so decided to leave it unattached.
pipe appears to stay in its place well enough even without the extra support so maybe not needed at the moment.
Support bracket v should be vertically approximately 1-2cm higher from exhaust mount to attachment points to avoid the chassis collision.
Update - got updated rear box mount from Ulter - fitting it in few weeks time
Ulter is next on my list. I'm more than happy with my HKS, but would like one with TUV to get it legalized. Their tips do look similar - Ulter black and HKS carbon ones. Maybe nobody will notice me driving HKS with Ulter papers 😉
I need that loophole for the Akrapovic :D But the 2x small silencers are a clear giveaway :D
Bit of a thread revival
I've been following this thread for a while, this system sounds a win/win especially with the HJS included.
Looks the ideal replacement when the stock system fails 70mm diameter as well.
I'm still searching for e re-seller in the UK found HJS about 10 mile away, can pay over counter as well.
Thought I'd found one , emailed but no reply, will search again and check.
Regards Russ.....🙏
Found it , just gave them a call, obviously not a stock item, but they have a delivery each month from Ulter.
So pre order deposit .
£740-00 delivered , .😎
AKtiv Performance Ltd and it's PayPal option , bonus for me. I'm not sure about posting tel numbers etc, I just googled Ulter UK and their details came up.
Big thanks to Onehp for the work finding this and Michael Knight for confirming fitment etc.
Along with their reviews
Regards Russ....🙏
I think you will be satisfied with it @Euge ! Mine car has gotten bit louder since bought it, although havent measured it in dB before / after so just subjective.
