GR Yaris DNA racing lower torque mount issue
CerN
Went to dealer today, because I've been having issues with gear shifts this past week. Unless I was really slow off the clutch the driveline would give a proper jolt. Didn't feel good.
Turns out it was my DNA racing lower torque mount. The bushing was completely split down the middle 😳 Only been on the car for 10.000kms.
So now the question is... What do I swap to? Was this just a defective part, or do these bushings DNA use really break that fast?
Not too fuzzed about going back to the stock one...
This is what I feared it (and wrote here somewhere) being not vulcanised around the axle, effectively meaning you have a point load wanting to split the bushing, rather then an evenly distributed load on the whole bushing.
Not sure if there is a stock vulcanised geometry one but with harder rubber, iirc perhaps Hardrace makes something like that...
So my best bet might be the powerflex insert on the stock part?
By far the quickest and cheapest solution, these inserts do eventually wear out too... I have the whiteline, which is a bit harsh but should last longer... Or just change the insert now and then when doing a bigger maintenance job.
I did install the Powerflex insert - very easy to install. To be honest I couldn't feel any difference... but I hadn't any complains from before either...
And the other good thing about it is that you don't have the feeling of messing with OEM setup: just OEM+ :)
edit: and BTW I have a spare one (new) for sale at Finn.no 😁
To me the DNA mount made a big difference in a positive way, and lately in a very negative way 😅
2000NOK to the dealer today just to find out I have to order new parts and jack the car up to fix it myself! I could have sworn something was wrong with the rear diff, never expected this. Oh the joys of modifying cars 😂
That being said, my local dealership is great, we had a nice laugh about it, and they were surprised to see the part fail this fast as well.
I think I'm going to order the black powerflex inserts and see how those compare. I don't mind some NVH. It's the cheapest option, so might as well give them a go.
Definitely expect parts like these to last way longer than 10k
Think mine is on the car for over 25000km. Still feels good, but will take a look at it the next time car will be in for service.
My brother has had it on his car for about 12.000km and his is perfectly fine, so maybe I just got a faulty one.
I'll send pictures to DNA once I've taken it off and see what they say.
Anyways, if you have to start letting off the clutch easily between changes to avoid hard jolts, and you feel a lot of vibration when pulling off with steering angle in 1st gear, then check your torque mounts folks!
Hardrace part that (I think) you're referring to:
Had it on mine for about 5000 km. No issues so far
I'm also running the Hardrace part. Lately I've been feeling that I've had to slow down my shifts a little bit again vs. before.
I do think that it is also subject to some pretty quick wear, might be some other cause though.
It might also be due to the fact that I've only done the torque mount and not the engine mounts which would perhaps place a bit more load on the torque mount alone?!
I think I'm going to order the black powerflex inserts and see how those compare. I don't mind some NVH. It's the cheapest option, so might as well give them a go...
So sorry to see this failure.
I hope DNA can sort sth out for you.
If you're considering the black Powerflex inserts (I understand you mean the ones that fill the void of the stock torque mount), perhaps it's also worth considering a black Powerflex replacement for the purple one that split instead (which you can get through DNA, hopefully on a good deal). Or any other replacement bushing that DNA may suggest to you.
Can't really figure out what these bushes are called, or find them on the DNA website as a separate item, but I'm not sure if I will trust this mount going forwards anyways. I guess I will see what DNA has to say. I already ordered the Powerflex insert, so that's going on the car ASAP. Will be interesting to compare.
Can't really figure out what these bushes are called, or find them on the DNA website as a separate item...
DNA describe it as TORQUE ARM BUSH.
... but I'm not sure if I will trust this mount going forwards anyways. I guess I will see what DNA has to say....
I don't blame you. You even have its newer, upgraded version. A mention on the DNA website about "All material ... intended to professionals and to use only COMPETITIVE, such as car racing. Therefore such material, because its intended use, is free from any form of warranty." is nonsensical in my view and doesn't inspire confidence. Your 10.000kms should have done nothing of this kind to what is probably the most expensive GRY torque mount on the market.
... I already ordered the Powerflex insert, so that's going on the car ASAP. Will be interesting to compare.
Fair enough. Give the insert a few hundred miles to bed in before jumping to any conclusions.
DNA responded saying I must have driven the car very hard and that they recommend their black bushes, and offered sending me them for free.
I have never tracked the car, and not done any hard launches from 0, so I don't think my car is driven any harder than the average GR Yaris.
But they still suggest I try the black ones, and that the added NVH should be fairly minimal.
Black and purple should be same cost to them and therefore either should be free to you on this occasion.
Given that the whole mount is an upgraded, more rigid design than stock, if you go for the black bush, I would expect the difference in NVH to be noticeable and overall NVH to be significant for a road car. Both Powerflex and DNA refer to their black bushes as intended for track use for a reason.
I guess the purple bush may still be a (free) option for you, if you accept that going against their advice means no further free replacement if it goes wrong again (which may be the case with the black too, but that will be more unlikely to split). Getting the black one in that case shouldn't cost you much (as it's only the bushes), but nobody would want the hassle to continue.
With the black bush option, there may still be further implications. For example, if you have no or only yellow Powerflex inserts in the other two relevant places (upper & engine mounts), a black bush in the torque mount should work better with black bushes all around. And before you know it, you may have rattles on a level that probably isn't justified unless you track the car. Nice direct feel, but if it feels too uncomfortable, you may then decide to pay to swap it for a purple one.
Decisions, decisions... I'm sure you'll make the best one for you.
Good to know that DNA provided prompt support and offered a free replacement (y)
That's what I fear, that it will be too much for normal use, with it already being a very rigid design.
Powerflex insert is en route and going in first regardless, and if I am happy with that solution, then that's probably what I will stay with.
I am not too keen on race car level vibrations, and I am also not to keen about swapping torque mount bushings every 10k 😅
beating the snot out of her is the case here, for sure ;-) but joke aside, I guess DNA wanted to give some compliance with the holes in the inserts, but induced weakpoints. a solid PU puck would be a better solution.
I am using the powerflex PU insert, because it was cheap. did 3 trackdays and appr. 5tkms on it, so far it holds. I did the 2 other engine mounts too though.
Mine is doing exactly this with the stock one, with a whiteline insert... 😬
You have to be really..... slow off the clutch, all nimby not epic performance like it once was from new! :cautious:
Better get myself a new mount! :( (y)
