Here’s what it should look like and what happens to them. It’s 3m tape and some pins it slots in to. Seems they heat up and then unstick.
View attachment 27529View attachment 27530
Update on wind noise , dealer doing it under warrantyKeep us posted mate. My local Toyota garage would just blame the wind noise on the TRD wind deflectors (although I installed them as a workaround). Interested in the revised mounting/door seal though.
I think I have the same issue and a couple of others have reported it too…. Dealer taking their time to get Toyota HQ support. Which dealer did you use? I might refer mine to them to hurry it along.Update on wind noise , dealer doing it under warranty![]()
I use Stourbridge Toyota and bromsgrove this Time,I think I have the same issue and a couple of others have reported it too…. Dealer taking their time to get Toyota HQ support. Which dealer did you use? I might refer mine to them to hurry it along.
My old hometown. I might do a road trip back next year in my Estonian GR. Might be sooner if Putin kicks off.I use Stourbridge Toyota
Great result @GR.KEV!Update on wind noise, it has been done under warrantyall is good now.
So if anyone has a noise, mainly round the wing mirrors, get to your local dealer![]()
It’s just the door seal. It has some pins to slot into and 3m tape. The 3m tape loses grip then it pops out the pins and creates a gap.Great result @GR.KEV!
Do you have an official Toyota description on any paperwork they gave you? Or is it just the door seal?
Is this visible? Different side to side?It’s just the door seal. It has some pins to slot into and 3m tape. The 3m tape loses grip then it pops out the pins and creates a gap.
Yes the photos are in this thread.Is this visible? Different side to side?
They done the door seal and the rubber triangle round the mirror, I mite coat a gel like Vaseline on them keep them supple.It’s just the door seal. It has some pins to slot into and 3m tape. The 3m tape loses grip then it pops out the pins and creates a gap.
Toyota will soon know about this issue, so the more that go back and get it fixed the better, they may make a modified version, doesn’t help it’s got pillar less door frames.Great result @GR.KEV!
Ah, ok. Mine is not like that.Yes the photos are in this thread.
Can you take a photo of the seal fitted with door closed near the B pillarI have had a door seal replaced part number T62381-52050 but has made no difference to stop the wind noise.
I have attached picture of the seal I’ve had replaced, could you tell me if it’s the correct one?
Many thanks!
