GR Yaris Suspension Secrets Seat Lowering Bracket
Hi mate, it got put back sadly due to one of the staff catching covid, it is going to be fitted within the next few weeks.
i just ordered one too will be here on monday.
Apparently they don't have any fitting instructions just yet?
No, that's what I'm doing, filming some instructions together with Tegiwa :D
sounds great i get mine monday not sure whether too try fit it or wait for your video haha
SW Motorsport low seat mount fitted yesterday, instruction video coming soon from Tegiwa. After speaking with Shaun, I removed the white plastic bracket that the two connectors attach to, this allows you to go much lower then 35mm, more like 80mm if you want it. The bracket is screwed to the frame from the top, so to remove it you need to pull the seat fabric and cushion away from the metal frame, it's not as big of a deal as it sounds and I went through it in the video. The two connectors are then just cable tied out the way.
The next obstacle is the seat side trim, this will start touching the carpet on the seat mounting points, so Shaun has trimmed his for max lows. I've left mine as is for now but might look at the price of a new one. If it's cheap I'd like to go lower!
They have a sliding version as well which has just been released which should allow almost all of the drop of the fixed version.
If anyone is in the midlands and is worried about fitting one, I'm happy to supply and fit for £180, should take max 2 hours.
I have the suspension secrets one and removed the plugs from the white plastic and relocated them and gained more of a drop and the trim touches the carpet too
Could go lower if I wanted to trim the plastic or just squash it down but it’s spot on where it is now
Hi Matt, did the 2 wing shaped trim parts at the back not catch first? Thats the problem I had when I was trying to fit mine. I believe on the dna seat lowering sliders they tell you to hacksaw them off.
Matt and ktgaz, to be clear: you both are talking about the oem seats without sliders fitted to these base mounts? And the new sw motorsports version with sliders moves the sliders to the middle of the seat and then around 30 mm lower as I can see....same principle as the dna kit?
I just bought the suspension secrets kit and I cant see any more improvement...its just a flat plate where you mount the sliders.....no more room for any more lowering, except thinner material. I want to testfit a recaro sportster cs
The one I have removes the sliders so whatever the thickness of the runner is the drop you achieve. It’s doesn’t need to be any lower now the height is ideal now.
