So I read this Torsen comment about locking increasing 10% with non LS oil and immediately
ordered oil without LS modifier and put it in.
I sometimes find the rear loses traction as the inner wheel lifts, not a big issue but it's there. Any additional locking will help the outer wheel to slip more and thus reduce inside wheel lifting. Not the same as a plated clutch but anthing that helps at the cost of a pint of oil is very welcome. And that 10% is at least for me noticeable I can already say, just as 10% more power would be noticeable to keep a slide going, or 10% change is inside wheel pressure because of different roll stiffness would be noticeable (thinking of mk2 here that reportedly is better in keeping a slide going)*.
What about the technical side? Two facts to know:
- The front Torsen is inside the gearbox and thus uses non-LS modified oil (that would otherwise mess up the gearchanging syncros)
- The rear diff Torsen is seperate from the ITCC clutch pack that regulates power distribution front/aft. The LS/LX oil spec is there for NVH but I have an exhaust so that doesn't matter I can't hear a difference anyway. And if the Torsen themselves says it's ok... Also Quaife ATB @GRavy_Baby
So henceforth, I'm putting my leftover LS/LX oil in the transfer case, and the non-LS in the rear diff. You do as you find best for your use, just a tip if you found similar traction issues...
Thanks to @GR_Jonas here https://www.gr-zoo.com/threads/gearbox-and-diff-oil.6537/post-100908
*mk2 has more roll stiffness in front with arb and stiffer springs, helping the rear inner wheel keeping to the ground better. Similar effect happens with aftermarket suspension with same higher rates front and rear, because of motion ratio that makes the front relatively stiffer, helping rear traction as demonstrated by AJ Clubsport among others.
