CFM on boosted section post-turbo is defined by engine displacement and rpm, turbo(boost) has no say. So counter intuitively, power levels (because of added boost) play no roll in pressure drop increase, the difference is fixed.
So question is at what rpm do you want response? Revving to redline every gear, lag isn't a big issue, nor is it on track with full view. Lower pressure drop actually helps reducing lag and partly takes away the volume increase in a high flow scenario.
Driving an unknown road waiting for a bend to open up and perhaps in a slightly lower gear then ideal for response (say 3rd at 3200k rpm instead of 2nd at a bit much 5000rpm-ish), lag does matter for driving enjoyment imho, while power gains are less important. Here volume has a role. Anti-lag or, in my case, left foot braking kinda circumvents this but for most it doesn't come natural. But having the IC+(involuntary) boost pipes I wouldn't mind a bit less lag, but I do like the better top end they allow but I would trade it for better response in the above road scenario. It's all a compromise, but it's driving goals that decide imho...
Edit: saw your discussion with do88, I've had the same. The above still applies imho, I'm assuming most customers don't want lag hurting straight line performance, they aren’t talking about road driving finesse...
