GR Yaris Corolla Oil Cooler
Toyota refers to it as the 'Cooler Assy, Oil', I've used that naming . The GRY part costs 740€, so 1k$ is in the ballpark and most likely correct. It's definitely not cheap, and certainly not worth the expense.
No, it's not worth the expense.
When it becomes an issue, the first thing I'll do is put an air duct on the factory cooler. It's worth something, doesn't put heat into the cooling system, and doesn't add a point of failure.
Now that's a VERY good idea that makes a lot of sense. (y)
curious about the chance of installing the additional coolant radiator of the MK2 GRY. - that in time would help the job of the water/oil permutator...
My assumption is that with MK2 they have larger oil to water heat exhanger as they add water cooling capacity.
In test videos water temp was rising quite high (+106'C) so this would explain water taking more heat load.
In my previous track session in hot ambient air, water temp did not rise above 90'C. Maybe current system could benefit from larger water to oil heat exchanger - that component is just quite expensive so not really worth changing unless running longer +3lap full monty stunts.
