GR Yaris LSPI discussion
Sorry but I am of the option that Toyota make rather crappy engines ( there I said it)
As long as the stock engine holds up, it ain't crap is it?
Aussies at least seem to be particularly bent into trying to extract the most rediculous horsepowers out of them though, which is both freakin' amazing (Lamspeed) and incredibly illogical at the same time.... that Rode car with 760 whp (is that 900 crank??) on a unopened block, what were they thinking?
Its not I suppose but I think it could be better given its a Toyota and their experience. It should be the best of current engine design and I don't think it is.
Its just my option.
I blame the Bean Counters. They phaarrk everthing.
At least it doesn't spin bearings.
wow... never heard before about that de-stroked version, that would be a frenzy reving engine! (as long the valvetrain is kept in check). Always loved over-squared engines... wouldn't be something if some day Toyota comes with an inline-6 "G28E-GTS"
maybe it comes with high boost mk3... not opening new thread for that.. yet.
8k redline and 2.5 bar, yes sir.
The Rode car was a marketing gimmick for them. Seemingly unlimited funds and an opportunity to blow up an engine and go viral.
They posted about being open and transparent about their findings, when I asked for context about their claim about the limits of the stock internals Ryan called me an uneducated armchair expert and a troll and blocked me. So that’s nice
@Onehp yes sorry I don’t mean all engines have shit tolerances from factory, I mean the engines that blow pistons from mega knock events. There could be wear allowing the oil into the combustion chambers
Could be fairly uneventful piston ring and/or ringland failure, which then not much later shatters the piston in a massive LSPI event, at which point none is any wiser what actually happened with all the debris... Just specularing and quite hard to verify...
Yeah absolutely. The only pattern seems to be cylinder 1 is the one that seems to let go first and I’m only speculating why
So many seem scared about too thin/too low oil pressure so would be odd that being close to the oil pump suddenly is a disadvantage, but who knows...
Another speculation: cylinder one is the one rocking the hardest in an engine prone to harmonics.
And people seem to have no concept of how high specific outputs they are demanding and associated cylinder pressures with tuning. 400bhp/500Nm or top trumps 800bhp/900Nm as we saw the other day on the G16E-GTS is the specific equivalent of a M5 with respectively 1100bhp/1375Nm or 2200bhp/2475Nm, or a Bugatti W16 with 2000bhp/2500Nm or 4000bhp/4500Nm... Hypercars which have quite a different budget to make their top line engines reliable - at much lower specific outputs...
And still people complain they are crap engines if they don't hold for those much easier to approach outputs ;)
One of those Youtube engine is Cyl 3 I think.
When I mention crap Toyota engines it was not directly directed at the G16E-GTS there are others. :rolleyes:
The 800bhp G16E is pure BS not to be taken seriously. Strap it to the dyno and run it at full load see how long it lasts. The count would probably be in seconds.
20 years ago the RB26 was making 1200BHP so big HP turbo engines are nothing new but that was an iron block, big difference.
As any other brand, Toyota has good and bad engines (few of them borderline of being crappy really)... but I like to think that the majority were leaning on the "good side". Within this group, some of them really excel, as the revered: 2JZ, 1JZ, 1UZ, 3SG, 4AGE's etc... and finally, the new addition: our G16E-GTS!
Yes, it could be even better (as any other on that list), but for its inherent limitations (capacity, 3 cyl, emissions, weight and price point) it's a f*** amazing engine!! :p
SAE Paper 2022-28-0023 A Technical Review of Low Speed Pre Ignition in Turbocharged Gasoline Direct Injection Engines has most everything you want to know about it.
From the Abstract:
The present review paper comprehends the details the conditions for occurrence of LSPI mainly focusing on cause and effect of the local auto ignition taking place inside the cylinder due to formation of contaminants entering from the top land crevice during blow-down and washed from the cylinder walls during direct injection wall impingement, the parameters effecting it and various methods to mitigate the LSPI issue in turbo charged gasoline direct injection engines.
Unfortunately, it'll run you $37 for the paper, 16% discount for members. I can't send it to people, but I can answer any questions that are answered in the paper.
Concerning the LSPI mechanism, there are three major sets of hypotheses for auto-ignition, and all three are valid given different operating conditions. The most widely accepted one being the interaction between liquid and gaseous phase. Long story short, oil droplets enter the cylinder either from the crankcase breather system, through the intake manifold, or from the piston crevice. Injected fuel impinges on the piston and cylinder wall...because DI has poor vaporization compared to PFI (note that atomization is still liquid fuel and not vaporized). An oil and fuel combination collects in the piston crevice. High piston acceleration causes the mix to be ejected from the crevice. The reduced oil droplets reach the auto-ignition temperature when the piston approaches (oil has a shorter auto-ignition delay than gasoline) TDC...and BANG as it pre-ignites the entire charge.
Some additional take-aways from various scientific papers on LSPI:
Lower coolant temperatures affect fuel evaporation and increase the chance of LSPI. Going from 75°C to 95°C reduces LSPI occurrence twofold.
Increased intake temperatures reduce LSPI due to improved fuel evaporation. However, excessively high inlet temperatures affect end-of-compression temperatures, increasing the tendency for LSPI. There appears to be a favorable temperature range, though the study did not provide specific details.
The orientation of spark plug electrode inside the cylinder does have an effect on LSPI. It would be interesting to check if standard plugs are threaded exactly the same. In such a case, spark plug torque would be even more crucial.
Ethanol in the fuel increases the chance of LSPI but decreases the likelihood of knock following LSPI. Although LSPI is unfavorable for the engine, it may not be mechanically critical if no subsequent knock occurs.
In competition they let you lower the fuel temperature by 13 degrees above ambient temperature.
