I have run 30 fr 32 r sinceIs this primarily because of the weight distribution or to help keep the car slightly understeery?
Also, how would handling change if you ran equal pressure or even higher in the rear?
True . There is also a variation in overall spring rates as the flexibility of tires is affected.Increasing rear tyre pressure slightly above FR pressure will help reduce understeer.
Going to give this a try as been wanting to experiment a bit with them.Increasing rear tyre pressure slightly above FR pressure will help reduce understeer.
