GR86 Wheel spacers help
Grblue86
Reading
I am searching for 10mm wheel spacers (I will be fitting longer studs too). I want slip on spacers.
I assume 56.1mm center bore is a must and have only come across these 3:
£30 for 5MM SLIP ON WHEEL SPACERS 5X100/114 PCD 56.1MM CB IN BLACK (PAIR)
£10 for Wheel parts direct 5x100/114.3 56.1 5mm GEN2 Wheel Spacer
£150 for Fensport Wheel Spacer - Eibach Pro - 10mm - 5x100 - GR86, GT86 & BRZ
Does someone have experience or any recommendations please? I am likely going to purchase the £30 option (the top one)
Problem you'll going to find is with a 5mm spacer, there is no way to get back the hubcentric ring. You'll have to rely solely on the nuts pulling in the wheel square.
the 10mm should be able to replicate the 56.1mm hub ring though....
