GR86 What oil temps are you getting?
86GR
I’ve been keeping an eye on the oil temps to make sure I don’t overheat it while it’s still tight and running in. Generally seeing low to mid 90s degC depending on how hard I’m pushing it. Which is pretty low I guess.
The temp is pretty responsive to load, will rise 2-3degC with moderate acceleration but cool back down again quickly when you back off. What is everyone else getting?
(You need to engage track mode to see the temps)
My wife's Audi has an oil temperature display. 95oC is fine. On the motorway the temperature can be over 100oC but drops back to 90 - 95oC in normal driving.
IIRC got the demo up to around 120C when I was reviewing it. 95C is really just cruising oil temp. I'd say you're not pushing it, though understandable given you are running it in.
