GR Yaris Tyres
GR.KEV
Dedicated member
Worcestershire
I am sure this topic has came up many times,
I had now done 24k on the std pilot sports and due to be replaced in the newyear.
So i am may be doing the odd track day car has lowered springs Collins remap etc, so looking at cup2 or zestino?
Going to keep the std tyre size.
Anyone used either off these tyres, or recommend better?πŸš—πŸ’¨
Couple of lads I know with similar mods to you use the cup 2 and rave about them.
Ive chose AR1 on spare track rims. (as I don't want to wear out expensive tyres on the road)
Cheers PhilπŸ‘
Think I might try the cup2πŸš—πŸ’¨
cup2 are reasonably priced but not maybe the fastest. depends what you're after. I'd choose predictability over speed if you are not after fast times. its more fun to drive with predictable tire on limit.
Just looking for a bit more grip realy, I don’t drive
Mad in the wet anyway, so and I like mitchelin s
πŸš—πŸ’¨
Has anyone experience with the Zestinos? Wondering as I ordered a set for my Mini for next season….
Cup2's are brilliant. If you want more grip then you can't really go wrong. I did 2 track days on 245s over summer and there was bugger all in it between mine and a Circuit Pack with 255/265s on (bear in mind I don't have the front LSD).
As a bonus, 245/40 on 18x8.5 gives almost perfect speedo reading as compared to GPS, plus the 245s are a lot easier on the wallet than 265s.
Yeah think I will stick with the std size tyre on the stock rims.
Cup 2 here we come πŸ˜‚πŸš—πŸ’¨
Slightly off topic but.. I’m really interested about your experience on having an open diff front/LSD rear. In particular oversteer/ under steer etc? Any noticeable benefits before/after OEM/aftermarket suspension upgrades?
πŸ‘πŸ»
πŸ‘πŸ»
I have a torsen rear / open front in a poverty pack here in Oz. Rear drive is improved significantly and it is easy to get the tail out on track if you so desire. Not so much in shopping trolley mode but sport and track definitely. I have aftermarket suspension which was fitted before the rear differential. That then was set with toe out front and rear. After the differential change I went back to rear toe in, damn thing was sliding everywhere in track mode and slower as a result. One fun wet sprint day my passenger and I spent more time looking through the door windows than the front. Took both of us about 5 minutes to stop laughing.
Day to day commuting is the same though you can hear the back end scrabbling on slow tight turns in caprparks etc.
No doubt the front torsen would add more traction again but when I looked at what had to be done to fit it I decided to do that some other time, like when the clutch needs replacing.
πŸ‘πŸ»
I had mine fitted not long after buying the car so I can't really say how it changed. In all honesty though I could barely notice any difference, but I'd never had it on track by this point.
πŸš—πŸ’¨
please read this thread first
Do not buy CUP2 tyres for track use
to each their own... I am not saying Cup2's will fail you on any track, but there definitely is a concern, especially in stock size
I ruined mine in a single day, while all my other tires -- PS4S, F1SS, CSC7 -- lasted quite a lot, and I paid extra attention every time.
About Zestinos... Soon we will see ☺️
I went for the 225/40R18 Zestino Gredge 07R this time, as my track is quite demanding low speed high grip one, so softs wouldn't last long
I think cup2 is ok but definitely not a race tyre as such. But requires also a gentle warmup
I had PS4S before and F1SS and CSC7 after the Cup2's, I would presume they should withstand the same abuse
I was checking pressures and temps every 5-10 laps (1km / lap)
I did 3-5 warm-up laps before full send, waiting for temps to raise above 70degC... so I don't see what else could have been done
I think Cup2 has a pretty soft mid section that helps with the grip but kind of collapses on the high grip surface of my lap
As I have shown in the other thread, most of my tire thread was really nice apart from one specific section
What was also interesting is that at around 90degC (which is the operating temp of Cup2) the sidewalls became extra soft
Anyway, Michelin was kind enough to give me 2 extra tires so at least hats off for that
Worth nothing, I met a guy with a Renault Alpine A110R (that is 1080kg!!) with 245/40 R18 Cup2s, with exactly the same mid section wear on the same track
Yes could be also surface and tire combo issue. Surface generates too much heat into tire which then collapses
Cheers for the info, I have them fitted now, after 25k on original tyres!🀣
It will not be used on track, just the streetπŸ€£πŸš—πŸ’¨πŸ’¨
