GR86 Trickle charging...
GR86GRY
Ok so having just picked up my car with a flat battery I'm keen to get it on the CTEK (mxs 5.0) pretty quickly.
The manual isn't much help on how best to do this. I've had cars that you can charge through the cigarette socket, ones where you attach the negative to an earth and the CTEK just says + to + on the battery and - to - on the battery.
Anyone more knowledgeable than me know the best way to do it?
Negative here make sense?!
I would probably attach the negative to the screw on the battery, highlighted in green below. The CTEK is quite good in letting you know if it's not connected right.
Thanks! I went with screw in the end which seems to be working fine, but looking at the pic I took of the Toyota tech tasked with starting my car, he just went + and - terminals :)
I concur - the terminals are nice and chunky and clean so no reason not to put your CTEK crocodile clips onto them.
The other way is to use the optional permanent connector option with CTEK so it's a simple plug rather than manually clipping them on each time.
I did that when I had a BMW M3 that I didn't use much and the battery was in the boot and hard to get to. The small flying lead made it a doddle to keep it on the CTEK but release quickly when required.
Nice, might sort that as the car will spend a decent amount of time sitting (at least at this time of year)
Had the same thoughts and have the same CX5.0 with AGM mode.
Does anyone know is it best to use the standard mode, I've presumed the battery is not stop start so won't need the AGM charge mode on the CTEK?
I've had mine on the standard mode twice now and it still seems to run fine. I couldn't see any mention of AGM on the battery or via the product code so left that off.
Think it's for higher power batteries, couldn't see if our batteries were labelled optima or odyssey - seems to be running fine on standard mode.
Instructions says:
"AGM option 14.7V/5A Use for charging most AGM batteries like Optima and Odyssey."
ctek
Mine has been hooked up to CTEK in standard mode since it was bought as I am waiting for PPF booking.
I am impressed by the notch in the windscreen area that allows the CTEK cables to be run out of the car with the bonnet closed.
On my cars/bikes that are stood for longer periods I run cables from the battery to a charger plug located somewhere I can access without unlocking the car. I plug them in once a month to charge fully then leave them unplugged.
I know maintenance chargers are intended to be left connected but I had 2 batteries that failed well before their time when I tried leaving everything connected / not in use. Since changing to my current system everything has been fine. Could be coincidence of course but I don't believe so.
Are trickle charges battery operated? I don't have any electricity in my garage and I am looking for something to condition my car's battery, as I've owned GT86 previously and that was prone to draining its battery really quick.
What should I get?
What should I get?
I've got a CTEK CS-Free portal charger (https://www.ctek.com/uk/battery-chargers-12v-24v/cs-free) it works as a jumper starter (kind of), battery conditioner and trickle charger.
It's battery powered and I've used to to jumper start and trickle charge my BRZ, it'll last about an hour before it runs out of juice however, which might be just enough to keep your battery alive.
Sorry to keep asking but will it keep my battery alive if I leave my car with it for a week or two? Would I just need to make sure to charge the CTEK’s battery every now and then?
The car itself should be absolutely fine if left for a week or two. If not it has a fault. It would be better to fix that fault than to find 'work-arounds' to it, particularly whilst in warranty.
No idea, as stated above the CTEK CS-Free only lasts about an hour in charge mode. This would be fine if you charge it and then drive it, but if your leaving the car in the garage for 3 months and only using the conditioner every week, it might not work.
If your garage has windows, a better option would be a solar charger:
Amazon product ASIN B084M5ZL5L
GT86's were notorious with their battery drain. Anyway, I'm going to use mine as a weekend car, and then I probably won't use it every week. And planning to leave it garaged over winters, so looking for some kind of solution
Here's a couple of pics showing how I've hooked up the CTEK M6 connector. I'll find a way to tie down the wires so they don't flap around.
You can see there's a nice little cutout in the black plastic that allows the wire and connectors to slide through under the bonnet.
I'm all charged up now. It's nice for me to get in the car and configure the infotainment without worrying about draining the battery.
Is this the connector you're using?
Amazon
Mine's been sitting on the conditioner for days now so something more permanent makes sense.
