GR Yaris Transmission or LSD sounds
GRY1955
Hi all,
Just driven my GRY for around 300km. Bought used with already around 3k km clocked. I noticed the following:
1. Whirring sound when at low or reverse gear. Occasional clunking noise too
2. Squeaking sounds which i think is from the rear when driving. Even on flat or smooth roads
Can anyone confirm this is normal?
Sorry if this has already been discussed anywhere here, I couldnt find any though.
Can only speak for my GRY, but I don't have any squeaks, clunks, or obvious whirring sounds in low gear. There are mechanical noises, of course, but nothing that really stands out.
Caveat there is my hearing isn't great, but I'm not deaf or anything.
Best to compare it to another one for peace of mind, and of course, it's under warranty so when you get it serviced they can take a look at it and fix any issues.
My car makes delightfully mechanical noises with clunky gear change . It has the
Most tactile sensations as you change gear . Not the worlds fastest change but you can feel the baulkrings engaging and occasionally in second saying more haste less speed please . Not driven a nicer box since the single
Rail Ford of yesteryear apart of course
My Lancia Aprilia which without any synchros gives the best shift ever but you need to double shuffle up and down or be very slick on upchanges !
I've got a noise that I only notice when both left wheels are on a different surface than the right wheels, so a different grip level (when under acceleration). I'm pretty sure that it's a little bit of diff whine.
Yeah, I get noises. Mild clunks, the noises of machined metal parts meshing together, a bit of backlash whine. It's all good. Reminds me I'm driving a proper car, not a jumped-up milk float ;)
As for the squeaking, try feathering the brake when you hear it. If the sound goes away it's just a pad kissing a disk in a tender embrace. Harmless. Let love flourish.
There is no doubt you can hear the rear diff on occasions but the whole thing is basically indestructible so press on and enjoy the noise ! .
I did put some Dynamat sheet around the rear floor and wheel arch interior . Very easy to use and gets rid of booming !
