GR Yaris Tragic accident at Nürburgring
azet
Absorbed member
Just popped up at me, do not know any details 😔 if anyone knew him or he was even a fellow forum member, my condolencies
This corner can be tricky. You need a smooth, controlled entry then throttle through the corner to keep weight in the back otherwise the car will oversteer. If you try to too prudent there you are going to crash. It's especially tricky with FWD or other front biased car. GRY has light tail. Add a bit of toe out with an unexperienced driver and it can quickly lead to tragic consequencies ...
Very unfortunate, and the main reason I have no desire to use my own car on track.
Well we are talking about the green hell here. Nothing comparable to a normal track with grass runaway. At Nordscheilfe, if you loose control you crash into a rail instantaneously. Even worse, most section are really fast so G are really high. The part were the crash took place is a 200+km/h left with rail immediately on the outside. The corner itself is highly dangerous with high probability of oversteer if you don't know what you are doing. You can't compare this to 99.9% of the track at which trackday take place. Take some place like Paul ricard for instance. You can push all you want, you will never finish in a rail. I have a lot of example of perfectly safe tracks here in France. Look at La ferté Gaucher, Les ecuyers, Clastres, Chambley ... All those tracks are safe.
I'm wondering if most recent fatal crash at Norscheilfe did take place there ? Maybe they should soften the bump prior to the turn to reduce the propensy to unload the rear of the car ... They did it to flugplatz afterall.
Really sad about this though. That's far too young to leave this world.
An absolute tragic loss, my thoughts are with all who knew him.
I've been going for 15 years now and lucky to have not seen any big crashes, though a couple of friends have been in (and over) the barriers, more than once. (I was there for 11 days last month and shared some photos on some of the fb pages of the TG-RR car).
It's a very risky game, but there's losses of life on the streets and roads of the UK, without the immediate responses of marshals and medics.
It's 'must-go' destination, even if you don't drive on the track, it's truly a petrol-head heaven and often referred to as 'the best place to crash'.
Again, condolences.
I think track is very good place to practice car handling and improving your driving skills safely, and its recommended for everyone.
But you must understand the limits of the car and your skillset, and improve gradually. You cannot of course exclude possible variables that come into play but in general track is 5000x safer place to push than open roads. Still, far too many drivers avoid track driving because they feel its too dangerous or bad for the car. It is not really, if you take care of the needed things and are cautious.
Nurburgring is of course different topic with its character and traffic etc.
But even places that are considered dangerous are ok to go if you know their challenges and respect them.
In Finland Ahvenisto track is also considered very dangerous place due to the fact that there is very little runoff areas, but it is also ok place to drive (and actually a blast to drive) if you respect the track and the limits of your skills, and approach the challenge gradually.
Totally agree,
I used to use track days as practice for sprints in the UK in the Pug 205, always used the free tuition if available, even when I had been there for years.
Anglesey being one of them, loved the old layout , Radar was the max attack for me !!
As said Nurburgring is a very different proposition , my condolences go to the family .
Regards .....Russ ...🙏
Mischa has talked about the incident a bit. It seems that the driver&passenger have been thrown out of the car during the incident. The two passenger were lucky enough to land without too much injuries but the driver have been unlucky with the car.
I heard of similar cases of car passenger being thrown out of it during accident but I always wonder how it is possible ... Energy must be so high for a crash to do this ...
when car starts to roll in high speed the normal seat belts do little, as they are designed to protect mostly only for front impact. so to be safe 5 point harness is quite recommended if you do high speed runs on challenging tracks. just because of this.
There was similar incident some time ago, was it Porsche test driver who got into high speed roll and lost his life in similar conditions.
And with bucket seats and harnesses seat mounts needs to be proper..
Nurburgring has been on the bucket list for a while but seeing the pace some drivers are doing on TF it might be safer to choose a track day. but everything can happen nevertheless.
New incidents this weekend, coolant crash with many wrecked cars on the course, and a deadly frontal crash on the roads outside.
Victim of its own success?
You can’t really get away from the coolant crashes there have been many over the years although there’s rumours the French Porsche GT3 that had the coolant leak also lost a wheel at spa the week before. A red Yaris was caught up in this.
Regarding behaviour outside the circuit it’s getting worse sadly and whilst there’s many opinions on what causes it that doesn’t stop the problem. Heavy enforcement is needed.
Absolutely I might say. YT vids have done their bit in that.
It's a bit crazy with some of the videos you see the obvious speed differential between some of the track users.
TF is definitely one of the most crazy things. As Michael said above, nordscheilfe is on my bucket list but if it happen it will be a trackday, not a tourist. There can be 400 car on track during tourist, no way this is safe. Too many car can have leaks ect and over accident happens really fast.
