Toyota 86 TRD 14R (JDM Import)
SiCaln
Dartford, Kent, UK
As a predecessor to Gazoo Racing taking the helm of Toyota performance, this is my TRD Complete car 14R. It is not the track version 14R60, but the street concept if you will.
21/06/2024
Here is my imported Japan-only TRD 14R, a road going version of the TRD 14R60 track car, modelled on the TRD Griffon that lapped Tsukuba in 0:58:407 with only aero and non-engine related mods. It has come with a few mods on it, the dealer-added TRD wing, LED light upgrades in the interior, feels like a TRD short shifter and i'll add anything else I come across.
After over a year of ownership, I have finally got the first few mods on the car, and also uploaded a youtube video with some how to's on there - please take a look if interested.
In the first video I have done a walkround of the car and installed the following, (TRD oil cap, rad cap, fuel cap, gear knob, document holder and Perrin boot closer), which I feel like the car should have had anyway!
27/06/2024
Continuing on with some of the smaller jobs, I have installed a TRD strut brace, TRD battery clamp and USDM rubberised boot floor mat, this covers all the way up the back of the seats too and has a stupidly large 86 logo on it!
10/07/2024
This week I have been starting to update the interior of the 14R. I have removed the stereo and ETC system, about 4kg of weight in total, they aren't needed whilst it is sat in the garage.
I have also installed a Grazio & CO 4.2 TT USB ports, as the JDM models didn't have a charging port. 2017+ and TRD interior trim parts from USDM model, BRZ auto folding mirrors and TRD kneepad.
Here is the wiring for the GPS for the ETC system, the stereo and the reversing camera removed
The Grazio & Co USB chargers installed
and the driver's and passenger interior trim update from the 2019 USDM TRD model
Added a console side TRD kneepad
Oh and I also found my Drivejoy, well an air freshener that was shoved in amongst all the wiring!
I have started on getting this road legal, first things first I changed the clear lights in the bottom of the door and replaced them with red from the UK model. The bigger issues also was the existing kmh only gauge cluster. I replaced this with a later UK 2017+ model with the little screen and had it adjusted to show the correct mileage and removed the bulb for the TPMS system that is not available on the earlier cars.
In addition to the cluster I installed the later model 2017 buttons and a GJP (Gerald Just Products) joystick to control the screen.
I also added a selection of new TRD boots to the interior.
Tried to stay out of the interior for the next update, done a lot in there!
So started with updating the VSC module to the 2017+ version, this is to ensure the buttons correlate with the gauge custer, but also I have slightly less obtrusive drive settings. When ordering from a breaker check here for the correct age, this is a simple retrofit for the the 2015 and 2016 models, needs re-pinning for earlier models.
I also added a LAILE Beatrush brake master cylinder stopper, have always had these on every car I have owned, they do make a good difference...but not in gold, got it re-powder coated black
and it wouldn't be me without another TRD part, so here you go, door handle protectors
22/08/2024
Next came a well earned wash and installed some TOM's red v1 tail lights (after a bit of a re-pin).
06/09/24
Next back inside, I had intended on fitting the auto-dimming rear view mirror but some wiring diffences stopped play on that one. Instead I opted to make the interior a bit more comfortable with the OEM armrest
23/09/2024
Small update this time fitted some TRD rear side spoilers and a P3 gauge
This image has been resized. Click this bar to view the full image. The original image is sized 2203x1469.
18/10/2024
Another one from the archive today, I have been storing a TRD MOMO steering wheel for the car since 2018! Time to get it on in this video, the wheel went on easily, unfortunately the wiring loom for the UK spec indicators was not a straight swap, so will have to probably get an auto electrician on that. I ended up figuring this one out, got a wiring diagram from some pics taken under a friend's dash, re-pinned and working great.
13/01/2025
Got all of the wiring issues for the wipers and lighting systems sorted, also added heated mirrors, JDM versions didn't come with it
Also prob a change of direction with the rear fog for the car, have found a great dual fog/reverse bulb
https://www.ebay.co.uk/itm/315472814961
Big thanks to this DIY for the mirrors from Markitect on FT86club forums
https://www.ft86club.com/forums/showthread.php?t=112848
14/02/2025
Have fitted a TRD rear lean brace, have the rest of them to go on, but not been under it yet
Also got the rear fog light working, didn't have to modify the bumper either thankfully
Also got the auto-dimming rear view mirror installed too.
30/04/2025
Slight change of pace for this one, I installed a Verus engineering bell cover housing.
26/06/2025
Managed to get the Kenwood stereo system installed, and the TRD interior panel.
01/08/2025
Forgot to add this one, for my 41st my wife got me a trip to do the rally experience at Brands Hatch, I think she just knew I was itching to drive my car!
I also finally got round to installing headlight washers and getting them to function as intended, no separate switch, off the stalk and only when the headlights are on, I have included a list of parts I used and a wiring guide in the video/description
05/09/2025
First "power mod" on this one, added a GReddy Snorkel intake and was always jealous of the US markets being able to drop the rear seats from the boot so figured out a way to do it.
07/10/2025
I have finally made a start on my audio upgrades, well post headunit upgrade. I have added 3-way component Focal Access speakers into the doors and dash, and coaxial Focal speakers in the rear, adding some sound deadening as i go. I also took the time to upgrade the door check straps to the GR86 versions.
27/10/2025
Audio install finished, well mostly, the Scosche adpater I was using doesn't work and is throwing errors on the headunit, so will figure that one out, but other than that.
Amp is in, sub is in, interior is back together (mostly) and video is uploaded.
10/12/2025
I had a local smart repairer come and take care of some of the smaller issues on the car, including chips on the front lip and bumper
and this weird one I can't explain on the driver's side next to the rear window
Still not addressed these ones yet, which seem to be common complaints for 14Rs
Before installing the TRD Aero Stabilizing Cover onto the rear of the car, I have issues with things labelled TRD!
14/01/2026
I raided my old box of mods, found a very old TRD keyring I forgot I had (2012) and installed a Verus fuel starvation door.
Can finally register it in march, so I will be focusing on the service items in the next few weeks.
05/03/2026
The day is almost upon us MOT in coming, many service bits to do beforehand.
Also found this lurking under the car, so that was a nice discovery!
16/03/2026
The day came and went, MOT day happened, PASSED.
I also wanted to include a little of my history with finding/purchasing and the future registration of the car, hopefully help some others who are considering doing the same.
Also here are some shots of it in the wild for the first time.
img_9272-jpg.13048
img_9273-jpg.13049
img_9274-jpg.13050
31/03/2026
Few mods in this one, added the TRD gearbox mount whilst I was doing the oil changes. Then headed to the engine bay to add the 2017+ intake manifold and the USDM TRD airbox, believe it or not I was never a fan of red accessories before this car!
Here is a before and after.
af24e3eb-5124-4449-9964-330e67223665-jpg.13131
img_9341-jpg.13132
07/05/2026
The 14R is now registered, been a busy time lately, my son had his tonsils removed and I have not been paid for a few bits of freelance work, so it isn't insured yet.
But private plates are on, added a rear emblem and put some of my old stored accessories in the glovebox ready for the road.
img_9550-jpg.13301
img_9551-jpg.13300
14/07/2026
Gave the wheels a good clean up and wax, do a bit of a deep dive on them and install the TRD canards to the front bumper, wasn't scary at all.
21/08/2026
My TRD has an STi! Well I have added some more STi parts anyway, trailing arms and a TRD sticker to each door (wasn't happy with first one's placement so new one ordered for that side!
If anyone is available, I will be at Brands Hatch for GoJapan, would love to see you there.
Here are some links from to my YouTube channel, Garage eightSix
Episode #1
- Intro to the 14R
Episode #2 - Adding TRD bits and OEM interior stuff
Episode #3 - Interior tweaks, removing ETC, adding USB ports
Episode #4 - Adding 2017+ dials and more TRD bits
Episode #5 - Doing some bits under the bonnet
Episode #6 - The first wash and adding some TOM's rear lights
Episode #7 - Adding armrest
Episode #8 - Adding 2 more TRD rear spoilers
Episode #9 - Adding TRD MOMO steering wheel
Episode #10 - Got the wipers and lights sorted, added heated door mirrors
Episode #11 - Rear fog light and auto-dimming mirror installed
Episode #12 - Install a Verus Engineering bell housing cover, visit a friend with a 14R60 replica in California
Episode #13 - Kenwood head unit install, with cameras
Episode #14 - My wife treated me to a GT86 rally day at Brands Hatch
Episode #15 - Adding headlight washes to the 14R
Episode #16 - First power mod and boot release straps
Episode #17 - Focal speaker upgrades, not the TOY set
Episode #18 - Sub and amp added
Episode #19 - Some paint repairs and TRD aero stabilising cover
Episode #20 - Installing a Verus fuel starvation door
Episode #21 - Full service before the MOT
Episode #22- 14R registration day! Mot time
Episode #23 - Adding 2017+ intake manifold, USDM TRD intake and TRD gearbox mount
Episode #24 - Install TRD canards and wheel clean-up
Episode #25 - TRD 14R is registered in the UK! Also some OEM+ additions
Episode #26 - STi incoming, added rear trailing arms and TRD stickers to the exterior
And we are up to date, will up date as and when new mods take place
