GR86 Subframe centering Kits
GRistopher
I read in a post on another forum that someone had used these after they found their car to be quite lob-sided from factory. he said they made a lot of difference evening everything up
There's a kit for both front and back
Front:
Rear:
They're not cheap but they may be a solution if anyone finds their car to be uneven. I know the rear of mine isn't the same from side to side. Has anyone used them before?
Rigid collar kits. Common on the Type-R's and some have said they make a difference. Have thought about them. Should be able to get them on the import sites
I'm not sure how much sense it makes on the rear seeing as the subframe is suspended on big fat rubber bushes? The front i do get but not the back. I was fortunate that my alignment was spot on when I had it checked.
My rear subframe was uneven before but was fixed with getting Whiteline polybush inserts for the subframe bushing.
I would do that first before rigidcollar. On my S660 track car, the Spoon rigidcollar made a noticable difference, I do plan on getting it for the GR86 one day.
