GR Yaris Service categorisation in MyT App
GR04_TNY
I recently had the 6 month GR Yaris safety check carried out at my local Toyota dealer. In the app the work has now appeared in the Service and Maintenance section but has been given the category tag of 'Repair' (see screenshot below). I assume there is also a tag for Service which would make more sense but as it is the first service action taken I cannot say for sure. Can anyone that has also had it carried out confirm this?
P.S. I don't want to start a discussion on how needed or not the 6 month safety check is - I've read many other threads discussing it and it's not my question :)
Mine is the same - I'll ask when it get the annual service next month.
I’ve got no mention of the 6month check, but two entries as a “repair”, both listed as “eCall malfunction”.
Same here, not best pleased about it. All a bit inconsistent from Toyota. I've got the receipts though but some aspects of the App are a bit useless.
Mine shows as oil change no mention of 6 month check and they got the mileage wrong so sorted it and got a second service showing and the wrong mileage again so I gave up
I had an oil & filter change when the mileage was 4800 they also did the 6000 ml maintenance check same time. I had the Transfer box , Differential , & gearbox oils replaced in December. The recall for a new eCall module was fitted also in December.
