GR86 Safe to rev temp?
PVGR
Trader
Berkshire
I noticed the redline is displayed very low when you first start the car.
This quickly disappears though, way before what I consider to be at temperature which for me is 90deg. I always wait till it's fully warm before revving it out.
What do others think?
Do you rev it out when the low redline is gone before it hits 90?
My current car has a separate oil temp gauge and the water temp gets to normal quite quickly, it takes a lot longer for oil to reach "normal" temp. In really cold weather the oil can take ages to reach temp, like 15 miles!
I'm with you OP. It's a nice feature but it reverts to the full redline long before I'd consider it safe. I don't know if it actually restricts the revs at that limit though, in which case I guess it's just a protection against revving the engine immediately after starting. I still drive gently until the oil warms up.
I find the oil temps get to 90c quite quickly in this car to the point I don't think the gearbox would be warm. There's a separate gauge on the menus among the tire pressure monitor etc
Always give it 15 mins with any car.
You definitely notice when the diff is cold. Takes a good 15-20 mins for it all to warm. Annoyingly, that's all my commute is.
Any extended scenic routes you could take?
Or you could try and find some tomatoes and peppers and cucumbers on the way home, that should extend your trip a little...
To be fair I think most people are being too careful.
The most wear and tear on engines happens when the engine is cold, the viscosity is at its highest, and becomes thinner and thinner as the heat is applied... Providing the oil is above ~50 you're getting near optimal lubrication anyway.
Mechanical sympathy exists for sure, but I'd tend to live by the temp to rpm x 10k rule
40 degrees - 4k
50 degrees- 5k
60 - 6k
etc etc.
Really the most wear is when you cold start that engine... well that and RTV failure I guess hah.
