I move the rears straight to the front, and move the fronts to the opposite rear side every 5,000 miles. Done it twice now and never had to reset the TPMS - it has always recognised correctly the new positions that the sensors are in.I thought you could rotate tires and simple reset TPMS.
If I rotate backs 4.5mm with fronts 6.3mm will the display just end up showing TPMS reversed (rears at top, front at bottom)?
Toyota recommends to do it exactly the opposite to get an even tirewearI move the rears to the opposite front sides, and move the fronts directly back to the rear every 5,000 miles. Done it twice now and never had to reset the TPMS - it has always recognised correctly the new positions that the sensors are in
Yeah, that’s what I do…. Just wrote it the wrong way around!Toyota recommends to do it exactly the opposite to get an even tirewear
Directional tyres, yes, they are designed to only rotate one way.At the risk of teaching Granny some egg sucking, but for those who may be unfamiliar with all this swapping wheels around - remember you can't swap sides if you have wheels fitted with with Asymmetric/directional tyres (such as the 'Goodyear Eagle F1 Asymmetric 6'). They can only be moved front to back etc,.
You are correct. I mis-remembered. It’s my Goodyear 4Seasons that have the [Rotation] markings, not my Goodyear F1AS6. I knew I’d seen it on some of my wheels, I just got the wrong onesDirectional tyres, yes, they are designed to only rotate one way… F1AS6 can rotate either way.
