GR86 Remedies after going past a gritter
FS1819
Devoted member
London
I use my GR86 as a daily to get to work. I’ve driven quite carefully for the last few weeks, and I hadn’t had anything until last Thursday. I had my car cleaned during lunch time for Lunar New Year, but on my way home I encountered a gritter. Being from Hong Kong and having never driven in winter in the UK, I drove past a gritter spreading thinking it were a tow truck. The lower left side of the body was covered in grit. I went straight away to a jet car wash in Tesco to get the stuff off. The exterior body panels and wheels could be cleaned easily, and I have identified just 3 tiny chips thankfully on plastic parts.
But have I done enough cleaning up after this incident? I have noticed there seems to be grit on the under tray but I’m not sure how to get it off. I’m now anxiously waiting for the touch up paint pen to arrive to I can apply to the chips. Do I still need to use something like diluted vinegar to wash the car? Thanks
While I know this is what could happen without PPF, I just couldn’t justify the extra insurance cost on top of the PPF. I tend to keep the car anyway and I am okay doing DIY every now and then
Could you wash it all out with a hose?
When trying to find a rattle on my GT86 I found one of the undertrays at the back was full of gravel. It's a bit of a trap.
Vingear is for chips, not cars. Don't worry about it too much, you've done more than most! It will be absoluetely fine, it's more the trauma of having your car peppered by miniature asteroids as you drive past it.
That undertray has been identified as a bit of a nuisance, owners in the US who have had these for a while have noted they get jam packed with leaf litter.
For one moment, I was thinking about paint chips 🤣 I will try to jet wash the under tray myself. If I can’t get them off, I hope the dealer will remove the grit at the next service.
Also, I have received the touch up paint pens. I will report on the end result later
Where did you get this from? And do you have a part number please?
Just a quick one @FS1819 does the touch up stick say how long its shelf life is?
The manufacturing date was 10/22 and the expiry date is 10/24. Couldn’t find any reference to how long it lasts after being first opened
Reactions: ZN8
It’s worth checking whether the stone chips are really stone chips to begin with. I had tiny white spots on my electric blue gr86 at the bottom of the front bumper on the drivers side that looked exactly like tiny stone chips that you could feel with a finger nail but they turned out to be either salt or grit that got really strongly glued to the surface of the bumper.
I used a tar remover and a clay bar to get rid of them and couldn’t find any since then.
If it is all stone chips then I’d recommend prepping the surface well by cleaning, claying and wiping with an IPA before filling them in. Make sure to shake the paint really well for it to mix properly.
Fill them in stages rather than one big blob per chip, as the paint will shrink a bit upon drying. This doesn’t normally take longer than a hour, but check the weather if you’re doing it outdoors.
Use a tooth pick or an artisan paint pen to be precise with it and have some IPA wipes at hand in case you go over the chip.
Thank you for your tips. At first that night I was horrified that my bumper and side skirt were covered in small black dots, but having used my nail to check them, I have narrowed it down to three real paint chips. I’ll do it when the weather is better as my car doesn’t fit in my garage. The paint itself comes with a pen tip so I just plan to use that
