@Michael Knight I am very sorry to bother you once more, but since you seem to be experienced with titan nuts / titan products I would like to ask you some questions regarding these.
I thought about using titanium wheel studs (replacing the oem ones, example picture is in comment #26) & titanium lug nuts but when I search for this particular combination in the internet buzzwords like "seizing", "anti seize", "use manual wrench" or "fasten the titanium lug nuts with less torque then you would the steel ones" appear.
One side says it is awesome if you are on a quest trying to lose unbalanced weight and the other side says you should only use titanium wheel studs with aluminium lug nuts or titanium lug nuts with the oem wheel studs toyota builds into the car due to titanium + titanium ontop of each other without anti seize destroys the lug nuts and you cannot remove them anymore. (horror scenario)
What is the truth here?
Would I run into problems using titanium wheel studs & titanium lug nuts together?
