GR86 PPF - Car needed for templates
Sticky
Vendor
Following the fantastic response to our Yaris DIY PPF kits I'm looking to offer the same quality and value for other models, and with this in mind I need to get my hands on a GR86 in order to make the templates.
I'd need your car for around 4-5 hours, or ideally a full day at our Barnsley premses, but can offer a lift/collection to the local railway station so you can bugger off to Meadwhell / Sheffield / Leeds for the day to do some shopping. The car will be thoroughly cleaned (we are detailers, so know what we're doing here too), and the only thing that will touch the paintwork is some low-tack adhesive paper sheeting. Absolutely no cutting of anything takes place on the vehicle!
We make the templates, digitise them and cut a test piece which is then installed on the vehicle to test the fit. After any necessary adjustments we make the real item and install to the car, filming this stage to make an instructional video for future customers.
In return for your time, you get our full range of DIY PPF installed for FREE, and a spotless car to drive home in.
Please note that this is for simple DIY items, so don't expect to get a full front end done. We're talking rear arches, sills and other vulnerable areas that can be installed by almost anyone.
This is a one-off chance, and goes to the first taker.
PM me if you're interested
I believe it's going to be late Spring before the new GR86 lands in the UK.
Yep, I'm being pre-emptive ;)(y)
Hi,
When my car arrives I am interested in PPF & Ceramic coating, whats the name of your business?
@Sticky did you make any progress with the GR86 đŸ¤”
I can have access to one whenever I like, but simply haven't found the time in the run up to the Christmas break. Should be sorted within a week or two
@Sticky , any progress with PPF for key areas on the GR86? The front and particularly the side sills look like they take a hammering đŸ˜Ÿ
The GR86 is on the Xpel database, so you can have any area of the car covered.
I had front end, sills, top of boot lid and some other small bits as to not waste any like sections of the rear bumper so I don't need mudflaps. If I could afford to do it all in one hit I would. May go back and do the rest after Summer but have lots of life things to get done this year. My detailer loved doing it, even if as I thought the paint was so soft.
I intend to have some of mine done when the car arrives. At over 5k for the whole car that is way over my budget, so its a case of doing the most vulnerable areas.
Does the super soft paint mean there is a risk of damage when the PPF eventually needs to be replaced?
Apparently door handles themselves are not on Xpel database which is unusual especially given they are a common touch area. My detailer is going to email them to see if they can template it. One reason might be difficult to wrap it around the shape / keyless entry may not work (not a problem for some but I quite like it using it). Not a big deal. Looks like they've done a good job templating the rest of the car and hiding edges as much as possible.
Yes, the Xpel templates are awesome - hard to spot until really close. My fitters got a few extra bits from non Xpel patterns and fitted those too like the top if the rear headlights.
Yeah mine had to template the door handles and headlight washers themselves but they've done a great job with it. Keyless entry/locking still works perfectly.
