Got an appointment for tomorrow morning, one good sign from this is when car isn't running there is no water getting from there. Over the night I left a towel on all the affected spots and they stayed dry. So my theory (I hope) is that AC condensation drain tube is partially clogged leading to increased condensation on the A/C unit, therefore dripping from it on the carpet.
Obviously Yaris is rare breed so documented issues like this are hard to find, but I've found some cases on forums of basic Corollas, Camrys and US based Tundras having same issue. Toyota uses similar design of the condensation drain in those cars and it happened it same way in them as well (wet passenger side floor, dripping from the center), reason being the drain hose being blocked. I've noticed that even in the morning there was still a wet spot underneath the drain hose below the car, so I guess it cannot drain it fast enough or completely... A/C functions completely fine when tested, reacted immediately to different temps, speeds and modes with no loss of power or any unwanted smells so I hope it won't need replacing.
