GR86 Oil cooler?
Electric Blue
Dedicated member
UK
Does anyone know whether the GR86 has an oil cooler? I've seen some conflicting information. I know that was one of the first upgrades to make for a GT going on track, so would be good to know if the new one is up to track work as standard.
It has a Oil to Water cooler, basically the same one used in the Forester. This will be is sufficient for very light track use, although if your doing serious track time its better to replace it with a proper O2A cooler.
I do have experience with adding one of those to my previous gen and it's biggest advantage is getting oil up to temperature quicker when cold and maybe lowering oil temps a little bit (I'm talking here about 5-7° celsius when ambient temps are optimal) during highway drive. In theory it's great piece in reality it gets heat soaked quickly during track duty and barely affects oil temperatures. Long story short If you'll start seeing alarming oil temperatures during tracking it's time to start thinking about proper oil cooling solution. In my opinion it might be sufficient for a few first track days but I wouldn't feel comfortable during longer sessions with just it when temps start to creep up to 130° and more (Yes I do know that "modern synthetics" are capable of withstanding such temperatures but I've seen too many horror stories about FA20s tracked without oil cooler to believe that it applies to Subaru engines)
