Michael Knight
Specific tire thread for Nankang NS-2R.
Did my first spirited drive yesterday with the tire and it performed well to my liking. Wasn't able to break lateral traction as on public roads but felt the grip is good even with cold tires.
Running the 255/40/17 size on ProTrack One's. (9J, ET45). Ran with 2.2bar pressure all around.
Tire is 50% Road / 50 % track spec from the manufacturer. Not the fastest on the track but likely sufficient for stock suspension.
General feel
Steering feel is ok - not maybe as good as with Michelin PS4S but you get quite connected feel to the road as tire is stiffer. Feels like Suspension would be little firmer.
Cornering Balance
Car felt well planted on corners. As said was not able to break traction in corners but would say car felt little understeery. Not maybe a bad thing, but it is to be evaluated better on track with warmed up tires.
Comfort
Definitely louder than PS4S. The sound is tolerable but maybe annoying on longer drives.
Wet performance
to be tested
Manufacturer info
Pressure & Camber recommendations
Optimum camber settings between -1.0 to -3.0 degrees
HOT Pressure settings
1,000-1,400kg 27.5 - 37psi / 1.9 - 2.55bar
COLD Pressure settings
As above but use the highest stated figures by weight for your cold pressures. For example <1400kg use 37 psi and work your way down after warm up laps.
Road Pressure settings
Use the car manufacturers guidelines.
General feel
Cornering Balance
Comfort
Wet performance
to be tested
Manufacturer info
