GRMN Yaris My GRMN Circuit Pack
GRMNHK
Fascinated Member
Finally got the paperwork done on my GRMN Circuit Pack in steel grey. I previously owned a GR Yaris RZ HP First Edition, and the car is a completely different beast.
Haven’t spent a lot of time with her yet as she’s getting PPFd at the moment, but will share some initial driving impressions (I’m no expert so take it with a grain of salt):
-steering is much tighter and less assisted than the GRY. Steering ratio feels quicker. (some have said that the rack is different despite GR not mentioning that in the spec)
-clutch bite is much more aggressive, clutch is slightly more difficult to modulate at slower speeds
-engine feels smoother on the revs also helped by the revised gear ratios
-chassis feels much more stiff and planted with the extra welds and especially with the bilstein suspension setup, much less body roll than the GRY. The lower seating position also helps.
-more engine noises, noticed I can now hear the release(blowoff) valve.
-mechanical LSD is a bit noisy at lower speeds.
Is the steering lock to lock any different?
the RZ and RZ performance are 2.36 turns from lock to lock.
So the steering rack is different from what I know as is the program for the steering assist (less of it). The rack is quicker than the GR Yaris and the GRMN has a larger min. turning radius (Toyota quoted it as 5.7 vs 5.3 on the regular GR Yaris). I never noticed the lock turns but I'll check and come back.
