I am probably one of the few people that are very disappointed in the out of box driving experience of the GR86. After going through a few tweaks and mods, I am finally happy how it's setup as a road car.
Note: Frequent track driver and have completed in autosolo for years, my cars is not setup for safe understeer and will go into oversteer with steering input alone with a neutral balance
OEM setup issues for me:
Horrible mid corner understeer, does not trail brake at all (No front camber)
Lack of rear traction, making power on oversteer easy but not progressive (High rear anti squat, very soft rear subframe + diff bushing)
Soggy rear end response (Very soft rear subframe + diff bushing, tyres)
Soggy brakes (Soft OEM pads, can't handle hard driving)
Weird clutch feel
Throttle pedal too far and long for heel toe
Engine sounds muted
Best mods in order what I value the most
Currently the car sits around 30mm lower, with 50mm wider front and 40mm wider rear track.
Front camber at around 2.3 degree and rear at 2.2. No front toe out to save tyre life and 0.1mm total toe in rear. Around 6 degree caster with the Pedder top hat.
Stock ARB and damper.
With the narrow not crazy sticky street tyres, it's easy to exploit the grip limit and turning the car with throttle and weight transfer.
Perfect balance for me now!
Weird clutch feel
Engine sounds muted
- Proper 4 wheel alignment - If you don't want to change anything on your car, PLESAE do this at the very least. The alignment from factory can be extremely wonky!
- Lighter Clutch spring replacement - Fixes weird clutch feel without drawback
- Cusco or other throttle pedal extension - I uses a Verus spacer personally but any will help. Makes heel toe much easier and reduces the big height difference from brake to throttle
- Front camber bolts - Adding front camber helps with reducing understeer and make the front end more receptive to trail braking
- Rear subframe + diff bushing inserts - Drastically reduces the floaty rear end and even help with drivetrain response
- Better brake pads + fluid - Finally can drive hard without spongy brakes, I use Endless MX72Plus
- Intake + exhaust of your choice - helps with making the car sound better
- GKTech traction arms - Massively increases traction on acceleration, you can use the throttle to rotate a lot more precisely without breaking into a slide
- Grow design lowering spring - More grip and body control without harsher ride, developed by the GR86 development driver Masahiro Sasaki. Kinda OEM+?
- Pedder offset front strut top mount - Extra camber and caster, OEM style design, so no bearing noise. Not needed if you happy with the front end bite with just camber bolts
- 25F/20R mm wheel spacers - more for looks but does look good. 25mm front will need more front camber than 2 degree
