| Carry out 6k/1 year intermediate service as per schedule. | Carry out 12k/2 year full service as per schedule. |
| Includes:- Replace engine oil & oil filter. | Includes:- Replace engine oil & oil filter. |
| Replace windscreen washer fluid. | Inspect drive belt. |
| Check all fluid levels & top up as required. | Replace windscreen washer fluid. |
| Inspect battery for leaks, security of clamps & terminals. | Check all fluid levels & top up as required. |
| Inspect cooling system, hoses & connections. | Inspect battery for leaks, security of clamps & terminals. |
| Inspect radiator & condenser for debris & signs of damage. | Inspect cooling system, hoses & connections. |
| Check wheel nuts for correct torque specifications. | Inspect radiator & condenser for debris & signs of damage. |
| Inspect clutch fluid. | Inspect air filter element. |
| Inspect brake fluid. | Inspect clutch fluid. |
| Inspect brake pads & discs. | Clean air flow meter. |
| Inspect steering wheel, gear & linkages. | Inspect brake fluid. |
| Inspect for under vehicle and underhood fluid leaks. | Inspect brake pads & discs. |
| Inspect tyre condition & inflation pressures. | Check brake pipes & hoses. |
| Check brake & clutch pedal travel. | Inspect fuel cap, fuel lines & connections. |
| Check operation of lights, horns, wipers & washers. | Inspect transfer case oil. |
| Check function of all warning lights. | Inspect rear differential oil. |
| Replace pollen filter. | Inspect steering wheel, gear & linkages. |
| Check seat belts for damage & operation. | Inspect drive shafts including CV boots. |
| Check installation of driver's floor mat. | Inspect ball joints & dust covers. |
| Carry out wash & vacuum. | Inspect wheel alignment. |
| Carry out visual safety report. | Inspect wheel bearings. |
| Lubricate propeller shaft & tighten bolts. |
| Inspect front & rear suspension. |
| Check exhaust system for security & leaks. |
| Check wheel rims for damage & tighten wheel nuts to correct torque. |
| Check operation of hand brake. |
| Inspect glass and light lenses. |
| Check operation of alarm system. |
