My recent run over the mountains at night has brought this back to the fore. I will admit to vacillating on this. I really like the idea of a rally pod with 4x 6" lights up front both from the look and the generation of light. Downsides are impeded vision, especially for street sprint events where you need to spot some corners closely and probable wind noise. I am pretty sure modern adhesives would be more than adequate to mount the pod on the bonnet but that isn't easily removable. If I use rivnuts (or whatever the other side of the equator calls these) then that effectively kills a bonnet should I sell... And the cost is significantly more than the lightbar solution. And it is possible that there will be too much light on high beam creating low beam blindness though I could easily wire the lights 2x2 and have the option of no extra, 2 spread or 2 spot, 2 spread + 2 spot. As far as I can tell the pod is legal and complies with our design rules (ADRs) and state modification laws but it only takes a policeman with a sense of humour deficiency to deem the car unroadworthy and then there is a whole list of pain to go through.
I found a local supplier of fibreglass pods though he has yet to fit one and get decent photos.
Smaller pod for 4x 4" lights:
.jpg)
Rally pod for 4x 6" lights:
Europe probably has more options but these are out there:
I prefer these last or the 4x 6" pod. Cost is pretty significant though compared to a lightbar. Bear in mind that the canbus interpreter still has to be fitted and a harness installed...
Either of the local pods is AUD400 and 4 lights will cost anything from AUD100 ea to AUD 250 each. I would go for led spots and spreads and these are at the higher end. Plus I would need to machine new bezels to face mount the lights which isn't a big deal but added faff around.
So I am leaning towards the lightbar behind the grille. I have been sort of gifted* a 20" bar which will do nicely though it has more throw and less spread than I like but I suspect behind the grille will improve that to some degree. In addition I have found that the Stinger CANM8 which I can actually buy will provide a 12V trigger for a relay. The unit is AUD200 and a local company who has fitted several will charge AUD100 for fitting and for that I couldn't be bothered plus I am not a fan of soldering into the canbus so they can take the risk on that.
Still thinking but heading this way...
* gifted means #1 has 'given' me the new lightbar in lieu of expenditure I have made on his behalf. Expenditure which is higher than what he paid for the lightbar...
