GR Yaris Japan Racing SL01 Wheels
lee1563
Zookeeper
Staff member
Do I just need new wheel nuts with a 60 degree taper for these and standard length?
Thanks in advance.
Sorry don’t know the answer, but they look so good on the GR pics when they are on the car please.👍👍
What does the manufacturer say the fixings should be? 60degree cone style or flat or something else? what size are the hubs as you might need a hub ring?
They will be 60 cone. You need to measure the bolt hole to see if extended shaft fits if it does, it’s a no brainier to use them. If they don’t could they turns of a normal 60 deg nut to determine if getting engagement
As above. The hub face thickness is the determining factor and most cheaper alloys like JRs are quite thick so it'll be wise to run shaft nuts or longer studs.
What is the hub face thickness on a stock wheel ? and would you measure from the end of the cone to back of hub.
No idea on a stock wheel but they use flat washer nuts with an insert you measure from the thickness of the hole after the taper. A BBS or rays etc will be 6 or 8mm. An aftermarket can be double that
