GR Yaris Hello there
The only feature I don't like is the failing power steering in fast driving but that luckily happens only in loaded front scenario on track. So it is there only in certain corners, and does not really affect overall performance. Just good to know its there.
It happened to me too at the nurburgring just after the big compression of foxhole, not funny at all.
Well may be the speed of +200km/h didn't help. ๐Ÿ˜…
Its manageable if your driving line is ok, but maybe not so if lots of steering input would be required
Hmm new Airtec wing - this looks rather good. Rally 2 wibes with no glueing needed.
Mรคhh looks a bit "rubbish". I wait for the RR. For me its the first and only wing who looks perfect on this car.
Just enough to not be too much and, especially in contrast to the TOM, it doesn't look like a foreign body. At first I thought the one from TOM's looked good too. But after I saw it in real life, no, no no...
Look, so sexyโค๏ธ๐Ÿ˜…. I know you already know him :).
Well this could be true, though guessing that RR wing will cost one arm and leg so maybe not very tempting in that sense.
Airtech is enough Rally2 style in my looks and love that little flow corrector wing - rather silly.
edit. But maybe I'm too old for the wings. Prefer subtle look - it has better WTF effect in stock form. Having wings, bells and whistles shouts too much "I'm fast, look at me".
As not driving corners above 160km/h every day wings are not so much needed.
I'm sure that active wings (eg Porsche 911) are automatically deployed / raised at speeds much lower than 160km/h.
Do you think it's only over 160km/h when they really matter?
well not an aero engineer but likely from +100km/h speeds to start maybe feel something.
manufacturers tend to give their downforce readings in 300km/h speed. as the effect multiples as square to speed, it is rather little effect in low speed.
So yes it only has effect in high speed corners, in my book its +140/kmh or so (as we tend to have mickey mouse tracks here in north).
If wing would deploy in lets say 140km/h it would maybe intimidate drivers to exceed speed limits - something that is not wished by anyone. so maybe that's one reason they deploy in lower speed, to give driver feedback you're going 'fast'.
With Hardrace bellypan car runs now cooler than before. reason for that is that I have DNA front subframe stiffening brace and due to this the bellypan is 3cm(?) lower than original setup + open behind the engine making the cooling pack work more efficiently. Good for summer, not so good for winter.
Will remove the stiffening brace in autumn just to get pan more up and better heat into engine, but leave it as is now as its soon already summer.
No big difference but maybe 5'C.
temps do not rise that high especially now with cooler weather so added the front mask back. seems to resolve the temp issue now so maybe for winter I'll keep the front chill mask on.
really impressed with Pirelli grip on icy roads. only issue is ABS kicking occasionally in and it has zero grip.
Quite sufficient power as driftable on 4th gear from 100km/h or 3.5krpm..
Are you on stock power ?
Ice track weekend was cancelled due to warm weather and water on track (really a pity) so chilling at home.
Cleaned quickly the hood inside and also the cabin - good with smaller car is that it takes not so much time to do cleanup.. !
yes that was really a bummer! hope we can get something together soon anyways ๐Ÿ‘
