The GR86 is praised for it's handling, that doesn't change when it's wet. You get good feedback on grip levels which is reassuring, you know what's going on. Some might not think that, those used to driving something else modern which is so refined it disconnects the driver from the road, it's ends up giving a false sense of security. Ultimately the biggest influence is tyres really, PS4s are good in the wet.
The GR86 is very confidence inspiring in the wet. If you trust and 'feel' what the car is telling you, you should find it very enjoyable and not have any problems.
It is different to some modern FWD/AWD performance cars where you can mash the throttle and the car sorts it all out for you, but that sort of caper gets boring very quickly.
It's better than the GT86, which is the only car I ever managed to spin on a wet road (and I used to have an air-cooled 911 with minimal driver aids!).
Checking the geometry is a must and the single best thing I've done so far.
My local motorsport garage knew, I'd avoid a Kwikfit type place. The GT86 is a well known platform. Had a good chat about what I was feeling and what I thought I wanted and they dialled it in. The first alignment was about £70-80 but any checks or tweaks will be a lot less and they record what it was before. Lot of my mates use them before track days and Ring trips to be absolutely sure. There's not that much to adjust from stock so I put camber bolts on the front to get a little negative camber. Done over 2k in it since and it's been superb. Scotland was so much fun. I often say that if I had the money to, I'd drive it all day, every day.how would one go about this? Is it as simple as turning up at a geometry place and telling them to look at it, will they ’just know’?
